Fuel pressure regulator
Dean
Post by Dean » 15 Jan 2013 09:27 pm
Hey all just a quick question, as I've heard bad reviews about these adjustable fuel pressure regulators...
Would fitting this likely cause me trouble in the future? http://www.ebay.co.uk/itm/FACET-SYTEC-A ... 3f10b5ed33
The reason being, my F7P is running bike carbs and it is shocking on fuel, and I'm paranoid that my fuel pump is over-fuelling the carbs and its just spilling out the overflow as I'm driving.
It also has a REALLY BAD idle especially from cold, and a lad told me that might be because it hasn't got a fuel pressure regulator and the pumps over fuelling it.
Re: Fuel pressure regulator
Post by classicswede » 15 Jan 2013 11:06 pm
What fuel pump are you running? What is the ourput pressure supposed to be?
Dean
Post by Dean » 15 Jan 2013 11:08 pm
It's an external 12v one although I'll have to dig up the specs tomorrow as the car is in storage atm.
I've read that on carbs I should be pushing around 2psi
Edit: Just went to my friends to check it out and all my locks are frozen solid :lol: can't even get to my de-icer because it's inside the car :(
Post by classicswede » 16 Jan 2013 01:20 am
Most carbs run on 2-3psi
a lot of electric fuel pumps for carbs have an adjuster on them to control the pressure. If there are no markings on the pump then you will need to check howmuch pressure it is actualy making. A pressure regulator would be a good idea to keep the pressure stable.
tattooer
Post by tattooer » 22 Jan 2013 10:51 pm
What carbs mate?
Dean
Post by Dean » 22 Jan 2013 11:31 pm
Kawasaki ZZR1100 carbs it's a facet fuel pump no psi indicators
Dean
Post by Dean » 31 Jan 2013 08:20 pm
Okay, recently fit a fuel pressure regulator and I set it up to 2.5psi (whether or not the FPR is calibrated correctly is another matter) and soon enough my fuel pump started making some interesting noises if I leave it running at idle - Do you think the FPR is straining my pump? I've had to open her up to max on the regulator to stop it from happening.
Got to be honest the fuel pressure regulator didn't do much for me - Maybe my Facet pump supplies just enough pressure as stock.
