Omex Rev Limmiter... F7P
Posted: 22 Feb 2013 12:04 pm
by Minimike87
Right..
I brought an Omex limiter a while ago to connect to the F7P Engine, I joined it in to the correct wires coming out of the coil, but it didn't work, i sent it back and it wasn't till after i read this:
http://www.volvo300mania.com/forum-uk/v ... 13&t=14406
It mentions on here about taking the coil apart and soldering it directly to terminals inside
but before i waste money on another one or break the coil, thought id check and make sure it will actually work?
Thanks
Re: Omex Rev Limmiter... F7P
Posted: 22 Feb 2013 01:29 pm
by volvodspec
jup, i'm very thankfull for it. it saved my engine when the throttle was stuck wide open :D http://www.youtube.com/watch?v=y6KDFIlYWRk
Posted: 22 Feb 2013 02:29 pm
by Minimike87
Thanks
That looks nuts! could you explain how to wire it up a littler clearer than that link i posted ?
don't wanna go taking it apart and wiring it wrong haha
Posted: 22 Feb 2013 02:59 pm
by Minimike87
"you take the coil of the renix (it's held on with 2 TX20 bolts) and then you solder 2 wires to the bottom of the coil clips for + and - of the coil. (I understand up to here) haha
the omex itself only needs a 15+ switched power and a ground. you can use the blue/red wire normally used for the idle solenoid for the positive if it hasn't been cut away"
what does the red a purple wire go to ? in comparison to these wires
Im confusing myself here sm43
Posted: 22 Feb 2013 07:09 pm
by volvodspec
i just used random colors :P
apparently i was wrong with the 15+ feed thing, as the thing doesn't need one :roll: here's the pdf with wiring diagram:
http://omextechnology.com/OMRLCLC.pdf
Posted: 24 Feb 2013 10:51 pm
by Nimminz
I wired mine up as follows:
black - Ground
red - Coil + (if you're using renix lift the coil out and it might say which pin is which
blue - coil -
It works with the wires just pushed in then the coil bolted down too but I'd solder it :wink:
works lovely with a straight through pipe :D
http://www.youtube.com/watch?v=lLMIHgjzPnQ
Posted: 24 Feb 2013 11:21 pm
To think... 5 years ago we were all trying to work out which Renix units had limiters built in so we could get the correct map without the limiter...
