currently I have:
+12v live from the battery (red) to power the wiring (existing loom feed to battery)
+12v ignition switched live (GREY) from switched igniton live to loom.
earth 0v (brown) from loom to engine/chassis.
a fourth wire that switches from 12v to 0v when the starter is activated. this wire is grey/white. and is show on the 440 wiring diagram as going to the 50 power line.
can anyone confirm weather this is correct, as at the moment im having to manually jump (activate using a 12v feed) one of the relays (I believe it is the fuel relay) to get the engine to spark.
im by no means new to engine wiring, but this has got me absolutely stumped. im led to believe the ecu may be blown, as it would seem its not telling the relay to activate, and liven up the fueling/ignition circuit.
also the mystery fourth wire, and its purpose has got me a little confused, and this could also be where the problem lies.
I have attached the wiring diagram im working from.
the fourth (suspect) wire is shown on the diagram as coming from terminal 4 on the ecu to the 50 rail at the top of the diagram.
any help will be much appreciated.
madseb
