F7p conversion
Posted: 07 May 2014 06:17 pm
by Scrapman
I have got a 340 with f7p engine conversion could anybody help me on how to adjust idle speed please
Re: F7p conversion
Posted: 08 May 2014 10:55 am
what fuel system is it running?
Re: F7p conversion
Posted: 08 May 2014 05:03 pm
by Scrapman
The standard injection system with ecu
Re: F7p conversion
Posted: 10 May 2014 07:06 pm
by Alex Laidlaw
There's no adjustment of idle speed, it should idle correctly if everything is present and correct. What is it actually doing?
Re: F7p conversion
Posted: 12 May 2014 06:21 pm
by Scrapman
It idles fast on tickover
Re: F7p conversion
Posted: 13 May 2014 01:15 pm
Could be a number of things. First thing I would check is that the idle air control valve takes it's air from the main feed to the throttle body, not a separate filter. It has to have some vacuum on that feed.
Re: F7p conversion
Posted: 13 May 2014 07:47 pm
by Scrapman
Ok thanks will try that first
Re: F7p conversion
Posted: 23 Oct 2014 11:57 pm
by driftking89
does it drop below what you state is fast idle if it does then while engine is running pull one plug off at a time round the throttle housing if there is a change in engine behaviour this means that the sensor is working so try that its quicker
