Starting issues.
Posted: 21 Feb 2015 03:53 pm
Ok so my 340 1.7 has been struggling to start sometimes, but always fired up no matter what, and once it was going it was a dream, drove spot on.
Here's what usually happens, i turn the ignition, two good pumps of throttle, turn over and add choke, it usually fires up, then dies, then i do the same again and it fires up and runs on the choke. I put this down to it not liking the cold very much recently.
However, i went out and washed it this morning, went back inside for a few hours, came out to pop to the shops and it wouldnt start, turned over healthy just not firing up?
So i went troubleshooting, tested the fuel pump by turning it over with coil hd lead off and pipe disconnected from carb, it was spitting fuel out so that seemed good, plugs and leads looked fine, didnt take dizzy off to look because its a bitch of a job when you have no worthwhile tools at home.
After head scratching and playing i gave up, but before i went back inside i gave it another go, full choke out and pumped the throttle, it started up, hey presto.
But now im wondering what caused this, would i have flooded the carb and then had to wait for it to disperse? and im right about the other starting issues just being the cold?
Or could there be a real problem? Fuel pump is weak or something?
I know the carb is good, Mac did a very good rebuild of it and once the car is running it drives absolutely spot on
Plugs/leads/dizzy are about 8 months old at most. I had about half a tank of fuel so not low/crap fuel.
The good news is its working now, but if this is a potential problem obviously id like to head it of.
Any suggestions chaps? My brains thinking weak fuel pump or restricted fuel (Filter?) I will order a filter and change that if somebody could link me one, for the sake of it as i dont know when it was changed.
http://www.ebay.co.uk/itm/Fuel-Filter-W ... 3395311f78 - is this the correct filter? If so i will order, as would not surprise me if that was causing it, i may be wrong though
Cheers in advance, Dan
