Gearbox and Diff spare parts / upgrading
Maxx
Post by Maxx » 03 Aug 2016 01:32 pm
Hey there, I'm new to the Volvo scene so forgive me for asking a simple question,
Does anyone know what other model Volvo uses the same diff and gearbox as the 340??
I'm having trouble placing parts for my rebuild,
Thanks in advance,
Maxx
Re: Gearbox and Diff spare parts / upgrading
Post by bogbasic » 03 Aug 2016 02:22 pm
I think it was unique, bar the 360.
Post by SteveP » 03 Aug 2016 07:46 pm
The gearbox parts are likely to be shared with any other Volvo fitted with the M45/M47 series gearbox (240, 740, 940) but the unit as a combined transaxle is unique, as bogbasic says.
Maxx
Post by Maxx » 04 Aug 2016 09:50 am
Thanks guys, so I can start scouring the local scrap yards for 240/740/940 gearboxes and diffs,
Were these all RWD aswell then?? Just with the gearbox mounted up front??
360beast
Post by 360beast » 04 Aug 2016 01:34 pm
The diff from the 2/7/9 won't fit as the diff on a 300 is bolted on to the gearbox the others it is in the rear axle so won't fit.
To get it to fit you would have to remove it from the casing and then it would probably require some machining to fit in the 300 casing.
Post by Ride_on » 04 Aug 2016 07:42 pm
Yes all RWD but with live axles, so rather different. Its not impossible to get 300 replacements and even LSD are doable.
The 4 and 5 speed gearboxes are slightly different and need different diffs. The front of the 360 gearbox is different to the 340 as the props and mounting points are different.
300 diffs vary by ratio, pinions must match crown wheel.
200/700/900 boxes share many internal parts and gear lever bits. Later 940s use M90 clutch/gearbox which is no use without massive chassis mods.
Post by classicswede » 09 Aug 2016 10:12 pm
some of the gearbx parts are the same but not all of them. Diff is nothing like anything else
