Strange starting klunk
Japper
Post by Japper » 06 Nov 2005 01:34 pm
When I fire up the old 360 from '88 it makes a klunking noise. Just one thump at the moment the engine fires. Does anyone know this? I thought it might be a broken engine mounting rubber.
Leather, leccy windows and mirrors, snowcap, foglights, open air filter, black roof upholstery. What more do you want? >a 2.3 turbo!
daffodil
Post by daffodil » 06 Nov 2005 08:38 pm
hi check that the exhaust down pipe is not hitting the cross member
if it is, like you say it will be the drivers side engine mounting
there are 2 types early are just rubber later are type of hydraulic filled with oil....hope this helps
5lab
Post by 5lab » 06 Nov 2005 10:56 pm
i'd go with exhaust too - a broken rubber (snigger) will often lead to that sorta one off clunk
Post by pettaw » 07 Nov 2005 01:28 am
or a sticky starter pinion gear, sometimes when the starters are on the way out they stick when they disengage giving a slight clunking sound. If you've got the energy, worth getting the starter out and giving the gear a good greasing.
Japper
Post by Japper » 07 Nov 2005 11:22 pm
I don't think it is the starter motor. The klunk is to loud for that and the entire car wiggles when it makes the klunk. Can it hurt my engine if I don't sort the problem with the engine mounts out?
