Does anyone know what size of allen key? (3/8 or 10 mm will not fit) that will loosen the oil sump plug. I've seen a special key in the Haynes manual, how would I get one - dealers won't supply.
Banzai,
Max.
Oil sump plug key for 1397cc, b14 engine in a 1990 340GL.
its not an allen key on mine - its a square plug. i just use my socket set - the 'big' square drive part on it is just the right size. so probably 3/8", square type
I have a 1/2" drive challenger imperial socket set which belonged to my grandfather....nothing like 'proper' pro quality tools (not that I have very many!).
In case anyone ever wants to borrow it, I have the special socket available to remove the oil pressure switch. It's not that rare, but a Britool (nice) 24mm DEEP socket with 1/2" drive....a fairly unusual combination!
