B200K 499962 and camshaft question
Posted: 16 Sep 2006 02:38 pm
by mgarageu
on the 1986 GL...what is its compression ratio? did not find any info yet...
p.s have bought the car recently...
Posted: 16 Sep 2006 10:05 pm
by Dan P
10,0:1
camshaft and pistons
Posted: 25 Sep 2006 08:00 pm
by mgarageu
have not looked yet which letter marked is its camshaft. is there any possibility to avoid interference by replacing the camshaft or are the pistons the bad boys?
Re: camshaft and pistons
Posted: 25 Sep 2006 11:46 pm
by Dan P
mgarageu wrote:have not looked yet which letter marked is its camshaft. is there any possibility to avoid interference by replacing the camshaft or are the pistons the bad boys?
Your cam should be an Y-cam, one step below A, try find a V-cam or K.
Personally I would go for a V-cam on the 2liter engine.
engine
Posted: 29 Sep 2006 09:33 am
by mgarageu
thanks. one more matter. is piston noise while engine cold normal on B200 engine? my experience is about B19A and B230FB - no noises there, even with more kilometres done...
Posted: 29 Sep 2006 01:44 pm
by Fuse
Piston noise when cold is normal in B200. B2x0 series engines are so called "low friction engines", some changes were made compared to B19,B21,B23 series engines to lower the fuel consumption etc.. but those changes weren't as good for the structural strength as they were for economy.. :P
noises
Posted: 30 Sep 2006 11:32 am
by mgarageu
i have a nice B21A bottom...maybe use that with my head etc... :?:
