exhaust on a 360
pyro
exhaust on a 360
Post by pyro » 06 Jan 2007 05:23 pm
howdy folks!
ive got a volvo 360 gle 2.0l the previous owner put (i think) a stainless exaust on it. but it bangs on the leaf springs and its wearing the exhaust away. it jus looks like the silencer is to big or the U-bend is to wide. its geting on my nerves wen im taking drunken students about so any ideas??
ben
ps ive checked the rubbers and there fine, the mounting brackets etc all apear fine
* Disclaimer
Mors Principium Est
SoLaMaNdA
Post by SoLaMaNdA » 06 Jan 2007 06:46 pm
Try replacing a rubber on the rear silencer (one nearer to the drivers side) with a big zip tie. This should remove excessive movement. I've had similar trouble when the car sags under heavy load and driving on uneven surfaces.
pyro
Post by pyro » 06 Jan 2007 07:14 pm
sounds bout rite, ill give it a bash wen i go back to uni, or in the cold and wet tonight
cheers, was thinking along the same lines jus wondered if ane one else had summat similar happening
* Disclaimer
Mors Principium Est
Bilbo
Post by Bilbo » 06 Jan 2007 07:59 pm
this happened on my car!! all i did was slackened the clamp[it snapped so i replaced] and twisted back box around a bit,retightened clamp....job sorted !!
SoLaMaNdA
Post by SoLaMaNdA » 06 Jan 2007 08:04 pm
Depends where its hitting. Mine strikes on the leaf spring in front of the rear wheel. Twisting it might work for your problem.
pyro
Post by pyro » 06 Jan 2007 08:07 pm
its hitting behind the wheel mount on the spring (dont know what to call it!)
but ill investigate further
* Disclaimer
Mors Principium Est
SoLaMaNdA
Post by SoLaMaNdA » 06 Jan 2007 08:20 pm
Sounds like twisting the rear silencer might sort it.
Post by petefarrell360 » 07 Jan 2007 04:05 pm
Yeah, I think you're right. Carl called over the other day and one of the rubber exhaust donuts on the rear section was missing, causing it to hang low and hit the leaf spring hanger, but replacing the rubber as it was the n/s one made it worse and pulled it tight onto the hanger. We think because it was hanging for long enough with out it, it's twisted it round, so yeah, get a new clamp, as the old one will probably be rusty, and free it and twist it round so it hangs right.
Sounds like someone spent some money on the car before you and looked after it to get a stainless system, might be a VOC one. I've yet to carefully look at the one on one of my cars.
pyro
Post by pyro » 07 Jan 2007 09:10 pm
yea some one has spent a fair bit on it, its had been in his family since new, the daily runner to the shops basically, but ive had no problems with it except the feckin braided cloth fuel pipes near the carb.
* Disclaimer
Mors Principium Est
Post by petefarrell360 » 07 Jan 2007 11:07 pm
Yeah those braided cloth covered fuel hoses are pants! I've replaced them on my 340 with fuel injection hosing. Why they weren't like that from new I'll never know if it's going to last longer!
Post by Chris_C » 08 Jan 2007 11:03 am
All 300's are shocking with exhausts if you don't properly line them up! Twisting the back box usually cures it on 340's and 360's
