Rocker cover removal..
Posted: 29 Aug 2007 09:56 pm
by S60-MBS
Hi guys..i tried search the forum but couldnt find anything about rocker cover removal..i want to renovate my B14 rocker cover as its rusty abit..any instructions on how to removew it would be appreciated..i looked around the engine didnt see any nut/bolts etc.
regards
Mo
Posted: 30 Aug 2007 12:04 am
by Vart
should just be three bolts and it lifts off. two bolts at either end hold the hose retainers to stop the hoses and fuel line to the carb flapping about. should come off easy enough, theres a gasket in there too.
Posted: 30 Aug 2007 01:45 am
by petefarrell360
Pretty much as Vart says. Do be careful when putting it back on, as the B14 rocker cover can be easily distorted if overtightened. Check in the green books section to see if there is any info there, might be some torque figures.
Posted: 30 Aug 2007 06:05 am
by S60-MBS
Thanks for the replies guys..i'll read up the books first and make it a weekend job to get the cover sorted..
Mo
Posted: 06 Sep 2007 08:15 pm
by S60-MBS
Well guys got the cover off and painted the cover and it looks alot better than before..also painted the freshly sanded exhaust pipe too as it has surface rust as result of being parked for ages..
now i managed to clean out and spray some of the filthy cylinder block too as you can see some over spray on hoses which i will clean tommorow
