Warning light blinking at throttle
Pappa
Post by Pappa » 10 Jan 2008 08:10 pm
Hi. Whenever i give more than 1/2 throttle on my 87 340 1.4 the warning light (diode) in the temp gauge starts blinking although the engine's not overheating.
Can this be the thingie between the air intake and the air filter? I think it's a thermostat or something? Maybe it's broken and starts giving false values when the engine's sucking lots of air? (Just a random thought). If this is broken, how does it affect engine behavior?
Post by foggyjames » 11 Jan 2008 03:48 am
Almost certainly the engine temp sensor wire is shorting to the engine (probably the rocker cover). The sensor is on the water pump....and it's the only wire in the area ;)
Pappa
Post by Pappa » 11 Jan 2008 06:10 am
foggyjames wrote:Almost certainly the engine temp sensor wire is shorting to the engine (probably the rocker cover). The sensor is on the water pump....and it's the only wire in the area ;)
Thanks. So the temp sensor isn't broken, i just need to do something with it?
Post by foggyjames » 11 Jan 2008 06:14 pm
The engine has probably rubbed through the insulation on the wire leading to the sensor.
Pappa
Post by Pappa » 11 Jan 2008 07:27 pm
Aha. 2 minutes and some electrical tape then, and a couple zip ties to keep it in place.
thanks
Post by foggyjames » 11 Jan 2008 07:32 pm
Exactly :) You may find there's no way to restrain it....it took 20 years to rub through, so tape should buy you a lot of time.
That was the issue with my 1.4, anyway. Yours may be different...
Pappa
Post by Pappa » 13 Jan 2008 03:34 pm
It did fix it :D I insulated it with some tape and cleaned the contacts with contact cleaner and a scalpel. Good as new! No more blinking.
Thanks!
Post by foggyjames » 13 Jan 2008 09:41 pm
No worries :)
