glt turbo
glt turbo
I want to install a turbocompressor in my glt they recommend to install a oil cooler l, that turbocompressor seems to them to be better: garret t3-t4 or misubishi td04h-13c that him changes to my 740 I have one td05 of my 760,The exhaust system in 2"5 or 3"?
Not sure exactly what the question is heer. As to the exhaust size I would go for 2.5" provided you are not after mega high power. If keeping a 2ltr bottom end then 2.5" will be pleanty
i think that the garret t3 from 740 turbo would be ok for you. If you can sort the ignition and fuelling then you can turn upo the boost to about 1 bar. And with decent fuel maps, intercooler and 3 inch exhaust. You'll be looking at between 210 to 230 bhp (If you change the 2,3 liter bottom end). And it will be fast compared to standard. Previous owner of my turbo said that with those upgrades it (740 Turbo) will start spinning wheel(s) on dry tarmac in second gear when it comes on boost.
1999 Volvo S80 T6 Quiet long distance cruiser.
1990 Volvo 360 GLi Waiting inspiration.
1989 Toyota Land Cruiser For days when wellies aren't enough inside the car.
1987 Volvo 360 GLi Being restored.
1986 Volvo 740 Turbo Sold, but not forgotten.
A Garrett T3/T4 hybrid is a very different turbo to a Mitsubishi TD04-13c or TD05-12B. The Garrett is a much larger turbo - you'll probably see full spool-up at about 3500rpm on a B230. The Mitsubishi turbos will be spooled earlier (as low as 1500rpm, even), but they won't make as much power at the top end, or be able to run as much boost. It depends on what you're aiming for.
Personally, I'm going to use something between the two - a T3, or a 'big' TD04 (18T or 19T).
I quite like to mitsi turbo for a smoth drive regular use car. Good power form low down and can give reasonable top end results. For a weekend car you will want a bigger turbo.
The other option I've not realy soon done on volvo engines much is how about a supercharger?
