accelerator cable
Posted: 11 Dec 2004 04:03 pm
by simon in alghero
Can someone help me.
A few weeks ago I had the accelerator cable replaced here in Sardinia. Only they couldn't get a Renault one so they "modified" my broken one. Well, surprise - it doesn't work.
If I can get the car to the Volvo dealer in Sssari - is this a resonably easy job? (presumably this would explain lack of acceeration, jumping, stalling etc.)????
Thanks to anyone....
Posted: 11 Dec 2004 04:16 pm
by DeKayDAD
Did this job on a 1.7 2 year back.Only takes 20 mins following Mr Haynes Dealer price for cable was around £15 (20 euros)If labour quote is for more than a half hour its a rip off.
Posted: 11 Dec 2004 04:36 pm
by simon in alghero
Thanks for your response....
They make a big thing of everything on the island!
Do you reckon I am better off tring to dive to Sassari (25 miles) or getting the part first and then trying to get someone locall to fit it?
Seems to be causing havoc with teh choke as well - is this normal?
Posted: 11 Dec 2004 04:46 pm
by DeKayDAD
I dont think there would be choke problems with the accelerator cable.Take the air cleaner assembly off for a better look and get someone to press accelerator.If cable works the linkages smoothly then problem is likely elsewhere.assuming its a 1.7 (the renault connection) it may be our old friend the solex28.34/air leak/carburation nightmare.
Posted: 11 Dec 2004 04:48 pm
by simon in alghero
oh dear - that sounds dire!!!!
have not idea what that is - but it really sounds like it might be a difficult journey back to UK
Posted: 11 Dec 2004 04:56 pm
by DeKayDAD
Dont panic it may be simply a loose carb bolt or two need tightening if it is an air leak or if its crap in the carb some carb/fuel additive injector cleaner through the system may work.Any more detail on symptoms
Posted: 11 Dec 2004 05:07 pm
by simon in alghero
Really grateful for your help.
yes it all seemed to start with the choke - once it was out it seemed to stay out and the revs just kept going up and up.
I had a look around teh bonnet with teh advice of some othe poeple on here. Part of the accelerator cable sstem was broken; if you artificially pushed it back the revs reduced.
I took it to my local garage here - on the wa I did notice that there was hardly any acceleration.
The managed to cut the accelerator cable before ensuring they could get a replacement - and then modified the old one.
Now it is OK whils the choke is out - although a bit ropey. Once the engine is warm it starts jumping and cutting out. Once again it feels as though there is hardly any acceleration.
Posted: 11 Dec 2004 05:19 pm
by DeKayDAD
If your bringing it back to the uk then I would invest in a new accelerator cable anyway. Theyre realy simple to fit and would take it out of the equation as well. If youve got a botched one on throw it away
Posted: 11 Dec 2004 05:27 pm
by simon in alghero
well it couldn't be much more botched to be honest - can't believe they put the old one back
once it is back in the Uk someone can give it a series look over but in the meantime it is nearly 1000 miles
thanks for all your help
Posted: 11 Dec 2004 05:37 pm
by DeKayDAD
Good luck have a safe journey
