Injectors
gltux
Injectors
Post by gltux » 18 Sep 2009 11:31 pm
Hi,
My 360 suddenly stopped working and wouldn't restart.
I've checked the simple things like a lack of petrol in the tank, spark, fuel getting to the injectors and fuses and all is right.
I borrowed a flashy lighty thing that plugs into the injector lead and no flashes. I've come to the conclusion that there's no signal.
That's where it goes to pot.
Anyone know why this could be, or if there's something I don't know (ok, that's a lot) that could be wrong?
Thanks in advance.
Fuse
Re: Injectors
Post by Fuse » 02 Oct 2009 10:15 am
Well there is a section in the wiring harness where the one injector lead from the ECU splits to four injectors. I've seen few cases where there has been problems with the connectors in that section. Though I'd double check the voltage with the multimeter to make sure that there is something wrong with the signal.
Re: Injectors
Post by classicswede » 02 Oct 2009 11:24 pm
First make sure you have power to them. Then as Marko has said that box can cause problems. It is normaly the (resistors) having correded solder causing a bad joint.
