The interior is in very good original condition. The seats are beige velour, the door cards and carpets are beige, the dashboard is black. It has original Volvo moulded rubber mats front and rear.
Below is a list of bad points about the car:-
-The rear OS wheel arch is crumpled in. I bought the car like this and it hasn't really bothered me.
-There is some rust, namely on the front valance, but also some to the sills and door bottoms. All this can be seen in the pictures below.
-There is some lacquer peeling off on the drivers side front and rear wings. This is where there has previously been stickers and the lacquer has come off with the stickers. It's annoying, but it's a cheap car.
-The exhaust isn't quite fitted properly and therefore fouls on the NS leaf spring. It is secured properly on its mounts, but it does vibrate against the leaf spring. The exhaust doesn't blow though.
-The drivers side electric window doesn't work. I think it needs a new motor, as when the switch is pressed you can hear it clicking, so the switch and wiring must be fine.
-The heated seats don't seem to work, but this has never bothered me.
-The sunroof is broken. I have never actually tried to open it, but I think the mechanism is broken in some way and the rear of the panel drops down when closed. The panel is supported up so it is sealed and doesn't leak.
-The central locking functions but doesn't work on the rear OS door, but since it still works on the driver and passenger doors, it hasn't bothered me.
I think I've covered everything in the description and the pictures, so there shouldn't be any surpirises when viewing the car.
I've got a spare diff from another 360, which can be taken with the car or seperately if you wish, but it's collection only.
The car is located near Derby.
I'm looking for £300 ono.
