Foggy's scrappage scheme - breaking 3 300s
volvomania
Re: Foggy's scrappage scheme - breaking 3 300s
Post by volvomania » 14 Feb 2011 01:48 pm
foggyjames wrote:Hi Robbert,
60! Crikey! You have quite a job ahead of you :)
I will have quite a few worn ones available in due course, as I have at least two sets to replace, plus whatever I have on spare struts. If it helps reproduction ones to appear, I'm happy to make them available. Exactly when I have them in my hands is another question...
The manufacturer is working on a numbersset for them.
Idea is to re-use the metal parts, except for the bush, as these are EXPENSIVE to reproduce.
Once I am approaching the 60 I'll be getting final numbers. (Will have to become a part exchange item.
60 isn't too many, only 30 cars to raid. sm4
So every one else with really lousy top mounts....
Post by Chris_C » 14 Feb 2011 01:51 pm
VM, I have some new topmounts, I've been keeping them stashed but looks like I'm going to be heading in a different direction.
For the sake of reproducing I might be able to part with them, but I can't promise (i.e., if I actually do need them sort of thing...) I'll leave it in your mind incase you need a new set and don't know of any.
samueljon
Post by samueljon » 14 Feb 2011 02:17 pm
Maybe interested in the front struts if you have any/arnt rusted that bad
Post by foggyjames » 14 Feb 2011 11:32 pm
SJ - The car is now on the trailer ready to go to the scrap yard first thing tomorrow, and I ran out of time and inclination to remove the front suspension. However, there are a few struts in my unit, including a pair which would be perfect for fitting new spring seats to (one has collapsed, and I bet the other is close behind). They're available quite cheaply. I'd be happy to part with those for very little money...
slim1122
Post by slim1122 » 16 Feb 2011 07:55 pm
foggyjames wrote:4 speed or 5 speed? I have a B14 5-speed box with a worn input shaft bearing, but the diff will be AOK.
how much dude and can you post? :D
Post by foggyjames » 17 Feb 2011 01:27 am
I can post, but it's not the easiest item. A lot easier than a complete box, I suppose! Where are you located? You never know...I might be passing!
I have no reference point for value...I've only ever given them away as trades for other items. Complete boxes tend to go for £50 or so, so I guess £25 or so for a diff?
Edokun91
Post by Edokun91 » 17 Feb 2011 02:08 pm
Need a offside wingmirror. some bastard smashed mine. just the mirror itself it you can help? :) 360gls
Post by foggyjames » 17 Feb 2011 02:30 pm
I believe that'll be the type that sits in the corner of the window, rather than on the door itself?
Do you need the glass, or the whole thing? Manual, I presume? Is it remote (i.e. adjustment handle inside the car), or a push-the-glass-with-your-fingers job?
I'm sure I have one...
Edokun91
Post by Edokun91 » 17 Feb 2011 10:31 pm
Yarh sorta in the corner of the window, its a '84 360gls, got like a plastic casing, little handle inside the car to move the mirror. only after the glass mirror case and mechanism are fine. someone hit it when it was parked up and it took the glass out and smashed it. drivers side yeah! let me know how the hunt goes :lol:
theo2468
Post by theo2468 » 17 Feb 2011 10:53 pm
ive got some if foggy doesnt
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
Post by foggyjames » 17 Feb 2011 11:39 pm
Things are a bit hectic here at the moment, so perhaps best if Theo sorts you out with this one. Good luck with it :)
volvomania
Post by volvomania » 18 Feb 2011 11:36 am
Chris_C wrote:VM, I have some new topmounts, I've been keeping them stashed but looks like I'm going to be heading in a different direction.
I have new ones as well but it are the old used and nasty ones that I am after.
(why destroy new ones for internal metal bits if one can take these from the old ones?)
Post by Chris_C » 18 Feb 2011 06:26 pm
volvomania wrote:I have new ones as well but it are the old used and nasty ones that I am after.
Fully agree about destroying news, it was just incase you didn't have any! Will keep an eye out for old ones for you.
Post by foggyjames » 19 Feb 2011 03:03 am
I'm sure I'm asking a stupid question here, but would it be too hard to have new metal parts made? Are they special in some way? We have reasonable fabrication skills dotted around here, but perhaps we can help? I guess if the parts are dealt with on an exchange basis, it's not a problem to use the original ones anyway.
Out of interest, which design are you looking at reproducing? I presume the late type? (I'm not sure of the years, but my 86 car (and all newer ones) had the late type, while the 81 car had the early type. Not checked the 84 GLT recently enough to be sure which it has). I'm not sure of what the difference actually is, other than that they look different. I'm sure they're all essentially the same, and you can use either style in any age of car.
volvomania
Post by volvomania » 19 Feb 2011 10:19 am
foggyjames wrote:I'm sure I'm asking a stupid question here, but would it be too hard to have new metal parts made? Are they special in some way? We have reasonable fabrication skills dotted around here, but perhaps we can help? I guess if the parts are dealt with on an exchange basis, it's not a problem to use the original ones anyway.
I am looking to do it on a part exchange basis, the metal bits inside are shaped in such a way that reproducing these (they greatly influence the set up of the vehicle if not correct) would make this particular project rather expensive looking at the small numbers I can expect to sell over time.
foggyjames wrote:Out of interest, which design are you looking at reproducing? I presume the late type? (I'm not sure of the years, but my 86 car (and all newer ones) had the late type, while the 81 car had the early type. Not checked the 84 GLT recently enough to be sure which it has). I'm not sure of what the difference actually is, other than that they look different. I'm sure they're all essentially the same, and you can use either style in any age of car.
James, that is a really good question. I am currently looking at the later ones as I was (and still am) assuming that these are interchangeable with the earlier ones. Have you ever measured the two?
