************* OFFERS ON ALL PARTS************************
breaking with a heavy heart, but due to lack off time to use and having the cash would be useful for my garage I have decided to do it. Most parts are very new and covered less than 200 miles , some are brand new like the 5 link rear that have covered 0 miles. Prices reflect the quality and age of the item , most of these parts are custom or adapted to the car many are extremely rare or unique . large items are ono , cash talks and no dreamers or messers . Also i dont care if you think it is expensive , go out and build this car and see what it costs you
car is located in dartford kent
some postage available at extra cost
Engine
F7p
Head gasket changed blew between cylinders
ported and polished head
skimmed head
all valves lapped in
very clean and golden inside the engine
all new gaskets
new thermostat
new cambelt and water pump £275
vgc flywheel and new clutch £40
spare vgc pistons, rods and crank £40
mocal 13 row oil cooler (front mounted with thermostatic sandwich plate) £110
new mandrel bent front pipe 2.25 stainless steel £60
complete Bandit 1200cc Bike carbs set up (on custom manifold), Facet fuel pressure reg set to 1psi, facet reusable fuel filter varley fuel pump and high pressure line £425
twin radiator fans £40
vgc radiaor £25
powdercoated headlight brackets £15
headlights £5 each
custom water system (sealed system with only 4 hoses and no expansion bottle and in hose rad. cap) £80
Williams exhaust manifold £60
full stainless exhaust motor bike back box £120
bell housing £35
prop shaft £60
welded diff gearbox good in all gears and v quiet £50 (no front mounts)
drive shaft £20 a pair
spare rocker box £10
bmw uprated engine and gearbox mounts and modified gearbox brackets £45
Suspension
GAZ custom fully adjustable coilovers with 200sx front adjustable top mounts £450 (covered about 30 miles)
Poly arb bushes £15
poly arb link rods £15
brand new GAZ coilovers fully adjustable new panhard rod set up , fully rose jointed, fully adjustable £750
S.V.A Hi Spec rear calipers , custom rear hubs with disc conversion . longer studs for wheel spacers . 400 for complete conversion inc. modified handbrake cables
custom bay power loom £25
variomatic front bumper grills £25
mini washer bottle with pump £10
wiper arms that sit lower down the screen unknown £15
Plastic door cards £25
de-badged inc. front grill £25
snap off steering wheel and boss and wheel £50
6 point roll cage custom made £600
flocked dash £80
rear light loom remade from trailer loom with large plug £20
Fibre glass bonnet inc bonnet pins £120
poly windows (fronts included not yet fitted) £ 50
Battery relocated to behind passenger seat inc. new large battery, battery box and power and earth cable and through bulkhead connecter £60
white weller wheels 13 x 6 ok tyres £80
Gold centred minilight alloys 13x7 (175/50/13) like yoko's on the front Michelins on the rear now battle scared £150
***please note the seats and harness' are not included in the sale ***
ok as you can see not your average Volvo 340!
Tried to be as honest as possible but please come and view and make your own opinions .
Please no messers
located in Dartford Da1 (5mins from the dartford bridge )
Any questions please call 07809 408 482
thanks joe
http://i973.photobucket.com/albums/ae21 ... 1987-1.jpg
http://i973.photobucket.com/albums/ae21 ... G_1720.jpg
more pics available on request
i finally did it.... broke up my very high spec 340
Re: i finally did it.... broke up my very high spec 340
Pmd
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Would you take 100 for the bonnet and pins?
Is the mandrel bent front pipe to fit a standard f7p manifold??
Cheers Ben
Cheers Ben
GulfPetrolHead
Is the bell housing off a 1.7 or a 1.4?
Facebook.com/GotCorn
shaunatkinson22
much for front coiovers set m8 wb shaun
Its had an f7 conversion so will be 1.7 bell housing.GulfPetrolHead wrote:Is the bell housing off a 1.7 or a 1.4?
This guy hasnt replied to pms, not sure where hes gone!!
Rev engine to 7K
Win at life.
