Volvo 340 strip down
Julian Breindl
engine is ok, Valves may need a check, 130000km
transmission is ok, manual 5 gear
clutch is ok, but the trigger is welded, but it works
body has just a little corrosion
3 doors, are all without corrosion.
Blaupunkt cassetteplayer dosent work
and the propshaft is broken.
with 4 rims but without cloak
its with german Paperwork
The car is located in germany 34270 Schauenburg Hoof close by Kasselits
My telephonenumber is 05601 925310
If you want it complete its about 250 euro but we can talk about the price
Re: Volvo 340 strip down
is it manual prop any good ?
thanks
thanks
Julian Breindl
my english is not so god, but I gues you asked for the propeller shaft? It works but ithave an unbalance, so i gues it would destroy motor and gearbox gradually
Hello Julian,
I just wanted to ask if the sunroof is still working and opens/closes correctly?
I'm looking for this part:
Those white plastic blocks holding the sunroof guide like to crack and split ...
Many thanks!
Many thanks!
Julian Breindl
Hey trabitom99
the plasticblooks are both broken, sorry
No worries, thanks for your quick reply!
LadbrokeOB
Hello,
I would like to buy the Choke Cable!
Also is the Carb good?
Many thanks!
Many thanks!
1988 1.7 340 Redline
Julian Breindl
Hey
the carb is ok, my motor runns good.
And the Choke cable aswell, is 70 euro for both ok? without shipping. Or you remove it yourself for less
Cheers Julian
Cheers Julian
iurgi340gl
do you have manual winder mechanisms on both doors? would you post them to the north of spain?
Julian Breindl
Sorry but the car is gonne
