FS Air con Unit
hatch360
FS Air con Unit
Post by hatch360 » 25 Jan 2010 12:05 am
From my silver GLT is up for sale.
Also Can you tell me what parts would make it a complete package :lol:
Not sure on a price so let the bidding war begin 8)
98 c70
87 360 GLT
93 Jaguar XJ6
82 244 GLT
84 240 GL
Re: FS Air con Unit
Post by volvosneverdie » 25 Jan 2010 12:27 am
One billion dollars. :shock:
vØlvØfreak
Re: FS Air con Unit
Post by vØlvØfreak » 25 Jan 2010 10:43 am
Mk2 or MK3 dash?
Can't find your grey car, only the red one... :wink:
EDIT: found it, it's a MK3, but some early MK3 models still have the MK2 dash..
this is MK3 dash with aircon:
Re: FS Air con Unit
Post by trabitom99 » 25 Jan 2010 11:04 am
Remember, a condensor from a RHD car won't fit in the LHD heater box. You'd be better off bidding on that German 360 Mark ;-)
Re: FS Air con Unit
Post by trabitom99 » 25 Jan 2010 03:28 pm
I'd be very interested in a part from the compressor bracket, the bit marked red:
If you don't want to split the bracket parts up, I might take the rest of the bracket parts too, but that depends on postage cost really ...
Jos360
Re: FS Air con Unit
Post by Jos360 » 25 Jan 2010 05:37 pm
Tom, can you not get that spacer from any hardwarestore? It seems fairly standard and not even necessary.
And another thing: have you ever heard anything of that would-maybe-fit Smart condensor that you were talking about some time ago?
Re: FS Air con Unit
Post by volvodspec » 25 Jan 2010 07:12 pm
or instead of the spacer, you can use 2 shorter bolts instead of 1 long one.
i would do either a 2 bolt setup or a long bolt with spacer on that, not long bolt without spacer. the big plate on that pic is castaluminium so if you don't fill up the gap between the bolts it will break, possibly during assembly but mostlikely under driving.
Re: FS Air con Unit
Post by trabitom99 » 25 Jan 2010 07:14 pm
Jos360 wrote:Tom, can you not get that spacer from any hardwarestore? It seems fairly standard and not even necessary.
Without it, you're always squashing the side brackets together at the top. It's not 100% secure that way ... I suppose I could go to a hardware store, but to be sure I'd need to remove the top screw and I don't really want to do that ;-)
The idea with the Smart condensor came from Tero Huikko: http://www.volvo300mania.com/forum-uk/v ... 41&p=85685
