What they worth?
Re: What they worth?
Ahh ok, want to get the360 checked after the two incidents at buxton and the sills abit deformd near the jacking point, chassis looks straight though, haveing trouble finding somewere with a jig that isnt a big body shop that wants a million a hour
Do. It yourself chap. Measure from front wishobe bush to diagonally opposite rjacking point spring hanger. Then front the compression strut pickup to diag opposite. Then both fronts to same side jacking point spring hanger. Make a note of each for reference.
Cheers mate i will have a look this week when i use the ramp at a garage i know, gotta figure out what the best way to sort this out on the 360, not even had the grinder on it yet and im already stumped lol, if anyone has any pics of how they did it post it up
http://www.volvo300mania.com/forum-uk/v ... 3&start=75
That's passenger side when mine parted company. Drivers side is a few pages on.
Chris_C wrote:http://www.volvo300mania.com/forum-uk/v ... 3&start=75
Forgive me Chris if you've later corrected this at a later stage in the thread and I may be wrong, but...Chris_C wrote:
v300_rear_sill.jpg by macplaxton, on Flickr
Some final adjustments to the holey layer (bellows? diaphragm I guess)
Interestingly, the proper Volvo panel is a fold short at the bottom, so will have to make a plate up for here
From what I can see of this repair, the Volvo panel is correct and IS NOT short of a fold at the bottom. As you can see from my badly lined overlays, the Volvo outer sill panel only goes as far as the white dotted line on the outside, the bit below is the bottom edge of the membrane sill with the round holes in it. That extends down to the red dotted line - bottom edge vertical flange with the drainage holes in there. Something like.....
v300_rear_sill_2.jpg by macplaxton, on Flickr
v300_rear_sill_3.jpg by macplaxton, on Flickr
The main sill ducks behind the rear sill about half-way underneath the rear door (green bit) The rear sill is one piece with the rear wheel arch (orange bit - lineage wrong at the back, but you get the idea).
That's the impression I get from your pics. I should really root around Ride-on's repairs to see http://www.volvo300mania.com/forum-uk/v ... f=5&t=8733 (or just get round to starting my own job
You are quite correct MP, I found this when doing further up the sill to be the case. I've never updated the thread!
Cheers chris i will have a look, were did younget your repair sections from mate? There was a guybon ebay selling them but not seen them for a while.
So is below the white line in that pic the inner sill but it just drops outside to the fed line?
