Green book has some confusing things
1980-1983 has spark plugs as 273597 - 5 from 1984 number is different and upto 1979 it is different.
There is no ignition timing for B14.3E, well only for 1984, but there is B14.3S, however S should have some sort of fuel cutoff at engine braking thing if I did read up properly, it is bit odd as there are other remarks to B14.3E being around on that time.
How these different engines were sold is mystery, maybe different model got different engine as different markets too, there are many of them, S and E models with those .1 to .4, lot of combinations.
Distributor is different in many models, maybe there is label of some sort revealing number, there are 3 types of points too on sale for that year model.
Technical specification pdf from technical resources has quite lot of data, need to check also what is chassis number of my car.
It just adds to confusion that for same engine code they have used many different parts.
Just need to translate that sparkplug Volvo part number to Bosch / NGK part number now, of course getting ones from Volvo might be possibility too
NGK plugs die so easily, Bosch has been winner in my 360, impossible to kill and I have tried very hard, NGK plugs died almost instantly at the start when I forgot to connect MAP hose to megasquirt, Bosch plugs seemed to ignore that ultra rich mixture completely
