Frits 343 1.4 Turbo ic
mefistofeles
antiekeradio
Hi there Frits!
Now it's broken.. It started to smoke like hell came up from earth and i had to screw it down to see what caused the problem. While the cylinderhead is open am i going to du some work with the mainfold, exhaust channels and lower the compression a bit.
Well, well.. Now the snow is gone and i have least 6months to make it run again but it wold be nice with some summer driving too..
Work on maan!
Work on maan!
@ mefistofeles: Me too, little weight, possibel for big power. Haven't been looking for informtation about the turbo 2 yet. I want megasquirt (or something like that) on it later. I think it is good possible to get huge power out of the b14.
@ Antiekeradio: Yeah i know, but i don't know yet or i want a long airintake to the turbo..
@ ale: You can't mean it! Make sure what it destroyed, or you will found the same problem after you replaced all. Use a wideband to tune youre carburettor. And get yourself a Renix 209
Buy a set of low compression piston set. In Holland here they aren't very expensive. (Or get looking for a complete GTT engine!)
@ ale: http://www.mbcarperformance.nl/catalog/ ... 77_796_799
Fixed the fuelsystem:
The presurre regulator
Now I need oilcooler + oilhoses and a welder..
I don't have new pics... but, I am a bit further again.
Fitted the side/front screens, bumper, headlights and the bonnet.. I amazed me a bit, because I thought the bonnent would't close with that GTT carb. But it can, so thats nice. No need for dirty air"intakes" or something.
About one and a halve month I will go for MOT.. So already checked all electronics, everything is ok.
Hopefully the oilcooler, pipes, airfilter, and oilthermostat will be quick here. Made a nice order at a dutch company
Thanks
I finnished them all, this week searching for little bended pipes for the manifold. I wanna finnish it!
The oilcooler, oillines, thermostat, airfilter etc order will arrive later then expected.. One part is on backorder....
Comming weeks a lot of time for the 343! Colleges at school are finished.. priority is making this car drive with MOT... Than the MOT of the 340.
The mid engined R5s (R5 Turbo, R5 Turbo 2, R5 Maxi Turbo) ran fuel injection but the MAIN difference was a totally different head.mefistofeles wrote:What is the diffrent between R5 Turbo 2 and the R5 GT Turbo? Are the based on the b14 engine and did it come with fuel injections in the late models?
Love b14 turbo! Smal engine, lots of power.
A crossflow head, like a Renault 5 Gordini Turbos.
Can be fitted to the GTT engines, has been done many times.
Normal GTT head can flow over 300bhp though, do dont worry too much, lots of other things break before you get to the heads limit, lol.
Stock crank and rods etc are good for over 250bhp though, they not shy.
