Page 1 of 4
broady81's 340 rally car
Posted: 10 Apr 2011 02:00 pm
by broady81
Hey guys,
Was speaking to theo last night, and realised that I hadn't got a thread up with my car(s). So here we go.
Bought a blue 1.7 340 back in November, with intent to road rally it. All was well and good, until it failed it's MOT on a number of things. While I was weighing up how much it would cost to get fixed, I came across a tidy looking 1.4. I decided, in my wisdom, that I would buy the 1.4, and use the 1.7 as spares, with the possibility of swapping engines at a later date.
Anyway, here is the 1.4 a couple of weekends ago before my first rally as a driver:
Amazing what Turtlewax can do :wink:
And here is a few during shots (you'll have to mind my ugly mug):
I've done what I would deem a "fair bit" of preparation. Tank and sump guards. Middle box removed. Brake line guarded. Lights relayed. Loads of other stuff that I'm sure would bore you all :wink:
If your lucky though, I might take some interior shots so you can admire my handywork :D
What d'yall think?
Re: broady81's 340 road rally car
Posted: 10 Apr 2011 02:27 pm
by MCHUDD
Hi mate your car looks a real stunner.
Love the front Hella.
Cheers Mark. sm4
Posted: 10 Apr 2011 02:45 pm
by volvosneverdie
Think that looks brilliant mate.
Even better than the blue un. 8)
Posted: 10 Apr 2011 07:05 pm
by theo2468
im thinking off cuttin the middle box off and just weleding a pipe in place of it. does it sound any nicer?
Posted: 10 Apr 2011 07:10 pm
by jon-ovlov
Thats clean! Real nice shine, car looks great. Nice bit of "whaaaaap" from the exhaust no? :wink:
Theo, Ive only got the one silencer before the right hander, so its a side exit. I would asume it doesnt sound to different from mine. personally, I think its awesome. Sounds like a V8 on tick over, only loud when you give it the beans.
Posted: 10 Apr 2011 07:13 pm
by theo2468
jon-ovlov wrote:Thats clean! Real nice shine, car looks great. Nice bit of "whaaaaap" from the exhaust no? :wink:
yeah i had the back box off mine for a little bit, did you just saw it off before the bend then?
Posted: 10 Apr 2011 07:17 pm
by jon-ovlov
I did yeah. Its a little ghetto, butu sounds great. Not your yobish "ricer" noise, its quite a deep rumble, very V8 like. (hard to believe :lol: )
Posted: 10 Apr 2011 07:20 pm
by theo2468
ive got a few middle sections in my unit, so with one im going to cut the box off and put a pipe in place and with the other ill cut it before the bend and weld a little bit of piping on so it comes out near the sill.
Posted: 10 Apr 2011 07:25 pm
by jon-ovlov
cool stuff. that'd do the trick. make sure its flush with the underside, inline with the jacking point. (not poking out). You dont want to get pulled for a dangerous object pointing out towards the people walking on the paths! :lol:
Posted: 10 Apr 2011 07:29 pm
by broady81
I got a local exhaust company to do mine. They cut the middle box out and replaced it with a straight section of the right bore. Nicely welded and properly sealed and clamped for £30. Can't complain.
The middle box had some nasty straight edges on it, and along with the tank, is one of the lowest parts on the car. Was scared into doing by a mate who warned be about some of the "whites" in Derbyshire (unsurfaced roads).
Sounds louder and is certainly a little raspier. Sounds the part I think, but then again, I did out of practicality rather than exhaust note :wink:
It ain't overly loud either. The noise restriction on the National B events I aim to do is usually around 98dB, and mine was safely under that with 87dB. I over revved it during the noise check too as I didn't have a rev-counter to work to.
Posted: 10 Apr 2011 09:23 pm
by Nimminz
looks good! very shiney
Posted: 10 Apr 2011 10:26 pm
On a 1.7, the bit whites like is the front of the mid box, and the 90 degree pipe from the mid box to the back box.
In a GLT... it's the rear diff cover plate
Posted: 10 Apr 2011 11:08 pm
by broady81
Nasty. Do you have a tank guard on Chris?
At the moment, I have a piece of dexion shelving bracket over my front to rear break line. A tip from a book I bought. Want to run it inside eventually.
I'm working on the break system currently. I really want to put discs on the back. Is it possible to put a 360 beam on there?
Posted: 11 Apr 2011 07:05 am
by volvosneverdie
broady81 wrote:Nasty. Do you have a tank guard on Chris?
360 drums are a fit. And an improvement. They didnt come with disks at the back though.
Posted: 11 Apr 2011 09:14 am
Yeah, forgot the tank... Fake's looks like someone's used it as a snowboard :shock:
I run a complete 360 rear axle. There isn't any huge advantage to it apart from the larger discs, but the limiting factor isn't the brakes themselves, more the bias valve.
