LPG question.
LPG question.
Post by volvosneverdie » 06 Jan 2012 09:40 pm
Firstly, please forgive my ignorance on this subject.
Ok, who knows about LPG, LPG systems, and LPG maintenence?
I know how to fill it up and press the switch button. Here ends my knowledge. So.....
Been tracking my MPGs using free generic mobile phone app.
all over same driving conditions....
Last tank= 24.81 mpg
Tank before= 26.58 mpg
Tank before that= 27.01mpg.
So it seems im going downhill. Quite fast.
Other that general servicing (which is not due) is there anything else obvious that could be sapping MPG?
Ive checked Tyre pressures and theyre bang on spec.
Is there a generic LPG service that needs done intermitently?
Re: LPG question.
Post by Speedy88 » 06 Jan 2012 09:43 pm
Best ask a fitter but I'd say maybe you've got a dodgy wheel bearing? Something's dragging.
mat_91
Re: LPG question.
Post by mat_91 » 06 Jan 2012 09:45 pm
strange one that shouldnt you be getting alot more mpg effectively on gas like 40mpg because of the price difference
ive working on a discovery 4.0ltr v8 on gas and that does effectively 30mpg
wheel bearings one there way out for a guess as it could produce more drag
i dont think lpg systems need servicing but im not lpg smart
mat_91
Re: LPG question.
Post by mat_91 » 06 Jan 2012 09:46 pm
snap wheel bearing haha
Re: LPG question.
Post by volvosneverdie » 06 Jan 2012 09:58 pm
Speedy88 wrote:Best ask a fitter but I'd say maybe you've got a dodgy wheel bearing? Something's dragging.
Cheers man.
Nothing else to suggest thats the case. No noise, wheels dont rock on jack and I dont think the brakes are rubbing either.....
Which is why I thought it might be combustion related.
Re: LPG question.
Post by volvosneverdie » 06 Jan 2012 10:00 pm
mat_91 wrote:strange one that shouldnt you be getting alot more mpg effectively on gas like 40mpg because of the price difference
Yeah man, thats ACTUALL mpg. So double it if youre comparing on price.
Dont think its a bearing or brakes. Though could be wrong....
mat_91
Re: LPG question.
Post by mat_91 » 06 Jan 2012 10:22 pm
what car/engine is it injection/carb
have you done a compression check one could be low so wouldnt burn fully and had it on a gas analyser to see if its running rich
Re: LPG question.
Post by volvosneverdie » 06 Jan 2012 10:24 pm
mat_91 wrote:what car/engine is it injection/carb
850 2.0 20v inj man. would have seen a drop in power on the throttle?
Coz I havnt.
mat_91
Re: LPG question.
Post by mat_91 » 06 Jan 2012 10:30 pm
your only slightly loosing each week so you wouldnt notice it id check get it checked just to be sure as what ever is wrong is getting worse judging on your mpg
Re: LPG question.
Post by volvosneverdie » 06 Jan 2012 10:44 pm
mat_91 wrote:your only slightly loosing each week so you wouldnt notice it id check get it checked just to be sure as what ever is wrong is getting worse judging on your mpg
Cheers man, thats a great help. I'll get it checked.
Re: LPG question.
Post by jtbo » 07 Jan 2012 02:21 am
After driving touch and feel your wheels and find out if they have started to warm up :wink: Just be bit cautious, they can be quite hotties!
Brakes can cause decrease in mpg without one even noticing how coasting seem not to be as good as before, one have to keep pedalling even on downhill, reason is brakes get stuck a bit, it gets worse and worse. It is not too difficult or even expensive to get brake servicing done when it is done enough early, but it does require taking brakes apart and then some cleaning and lubricating to make everything slide back and forth without too much of resistance. Also when brake pads are getting worn piston enters so deep that it gets bit tight in there and backing up provides bit difficult, nothing that good honing would not cure, but it takes few hours tires off and car up + saddles at bench, will save money back in a year for sure.
Re: LPG question.
Post by volvosneverdie » 07 Jan 2012 02:07 pm
Thanks for that J.
Ill check wheel temp next time I do a long run.
Ive learned on the VOC forum that the LPG system should have its own fuel filter, and that running LPG does go through plugs quicker, so I think it just need a full service.
I'll try that, check what J suggested, do a tank and report back!
Cheers all.
