Volvo 340 Vario Virgin
Posted: 30 Oct 2012 03:29 pm
Hi
I've just purchased a 1986 Volvo 340 CVT its Slate blue 340 DL 3 door. I'm totally new to Volvo 340 ownership, although I did have a volvo before which was a 1971 Volvo 144 DL about 8 years ago.
Can anyone advise me where I can get things such as Vacuum pipes and other spares for this car? I'm keen to make it 100% and I need to track down a few bits.
1st the feed pipe for the Servo looks a bit frail where it joins the inlet manifold, does anyone out there have a spare or can they advise what pipe I'd need to change it? Is there a standard rubber Fuel hose that is the correct diameter?
CVT hoses, I'm trying to track down some pipe for this as the vacuum feed pipe from the 4 way valve to the clutch disengage servo has a crack in it. Its a hard clear nylon pipe can anyone tell me what diameter and where I can get some from as I don't want to disturb it unless I have replacement pipe handy.
I've got a strange fault where the speedo works but the mileage doesn't increase. I'm guessing I'll need to remove the instrument cluster to resolve that, is there a method to follow? I also need to replace a couple of dash bulbs as they are non functioning. Anyone know what type they are?
Window scraper seal, I need one of these for the drivers door as the original keeps falling off. Can anyone tell me where I might find one?
Many thanks for any help and advice
