What brand is my dashboard instrument panel?
Hi.
I have to order the part in the left front wheel, to the speedometer..
When I changed wheel bearings i accidently broke it.
And when i call Volvo they tell me there are two different manufacturers of the instrument panel, and they have to know what brand mine is to get me the right part..
Either VDO, or another brand he said.. I can't see anything on the front of the speedometer / instrument panel..
My car is a 87 360 GL with B200K.
Anyone who knows the brand of my panel?
Thanks.
Thanks.
1987 - Volvo 360 GL B200K : 266000 km
The head nurse spoke up, and she said leave this one alone
She could tell right away, that I was bad to the bone
RandomHero
Re: What brand is my dashboard instrument panel?
Then you have the VDO gauges.NasoNex wrote:My car is a 87 360 GL with B200K.
antiekeradio
Are you 100% sure?RandomHero wrote: Then you have the VDO gauges.
speedo cable
My 'oar' in again.
In the UK the change from Smiths to VDO instruments came with the intro of the '86' year model (started at ch.no.120000) But on Nordic markets the change was earlier - at ch.no.099706 (late in the run of '85' year models).
If NasoNexs' car is an '87' his ch.no. will be above 241001 - so VDO without a doubt.
NasoNex - the part no. you need, I think is 32075601 - but there was a production change and I think this was replaced with - Cable 3207948, adapter 3208259 and clip 3120415. BUT I am a bit 'sketchy' on non UK cars so don't take this as gospel - CHECK with your dealer before ordering.
(your dealer should know all this anyway).
Good luck Mac.
Good luck Mac.
If the rev counter tops out at 8000rpm, it's a Smiths cluster. If it's 7000rpm with red inserts, it's VDO.
