URGENT!!!!!wanted: Front X-mem for 360 and GLT Diff
Posted: 15 Aug 2012 04:55 pm
by Nimminz
EDIT:
Am after a front crossmember. Its the tubular one that has the central ARB mounts. For 360 GLT '88. Don't think there's much difference with 360 ones. Kinda bent mine
Also a 3.64:1 360 GLT Diff, casing and pinion - the lot. would even take it stuck to a 5-speed box if the price was right
If anyone's got one and could brink it at the weekend to the meet, would be mint!
Got two diffs with a 3.64:1 ratio and no pinion shafts to match - it's not urgent at the mo, but wouldn't mind them, espeially if anyone has one they can part with who's coming to yorkshre in september for the meet. Have diff cases so just the shaft is preffered
Cheers,
Matt
Re: wanted: 3.64:1 Pinion Shaft
Posted: 17 Aug 2012 06:25 pm
by sven360
IMHO it's not good practice to mis match C/wheel and pinion.
Buy a complete unit would be my advice.
Posted: 17 Aug 2012 09:04 pm
by Nimminz
even with the same ratio? ah well, i have 2 useless but working diffs :( will buy a complete one when i need it then
Posted: 17 Aug 2012 09:43 pm
by sven360
I'd be happily proven wrong,just not summit I'd do myself.
Complete unit should be cheap enough.try FJ.
Re: wanted: Front X-mem for 360 and GLT Diff
Posted: 28 Aug 2012 10:06 am
by Nimminz
BUMP
Edited first post
Re: URGENT!!!!!wanted: Front X-mem for 360 and GLT Diff
Posted: 30 Aug 2012 09:06 pm
by Nimminz
Could REALLY do with this x-member at the weekend!!
Posted: 14 Sep 2012 10:02 pm
by Nimminz
BUMP
Ned this x-member curently driving with no front ARB
Posted: 22 Sep 2012 09:36 pm
by L14MNP
Did you get one mate? I have the one from my mk2, but I think the ARB mounts differently?
Posted: 26 Sep 2012 11:42 am
by 340GLT
a 340 one will fit if you cut the engine mounts off.
Posted: 28 Sep 2012 10:52 pm
by Nimminz
I currently have a 340 one on with the engine mounts cut off, Only problem is the ARB mounts are rotted through :/ Liam's sorting me one though :D
Posted: 28 Sep 2012 11:28 pm
by L14MNP
Nimminz wrote: Liam's sorting me one though :D
Forgot to text you Matt. Picked it up from the garage this afternoon for you mate. 8)
Posted: 29 Sep 2012 04:53 pm
by Nimminz
Spot on mate, I'm away this weekend but I'll give you a text when I'm back and see when i can come retrieve it :)
