RUBBER RING FOR ONE SIDE OF EXHAUST
Justin
Post by Justin » 18 Sep 2013 02:52 pm
I need a rubber ring that holds one side of the exhaust to the car at the rear end as my old one has split. I may try super glueing it back together? The part number is 224353...
I suppose I could always use a zip-tie although that'll probably be an mot failure?...
1988 340 1.4 DL
Re: RUBBER RING FOR ONE SIDE OF EXHAUST
Post by macplaxton » 18 Sep 2013 03:44 pm
The number moulded on it is a legacy number from the DAF days. :wink:
The actual Volvo part number was 3100099, but I think they are an obsolete part. Go down to your local motor factors / parts accessory shop / ebay / Halfords and ask for:
Bosal 255-397 or equivalent.
I bought two the other day from my local factors and they were only 74 eurocent each (60 cent + 23% VAT here)
Justin
Post by Justin » 18 Sep 2013 04:00 pm
Many thanks...
Would a zip-tie be an MOT failure?...
1988 340 1.4 DL
Logan360
Post by Logan360 » 18 Sep 2013 06:12 pm
I'd imagine so. its not OE and the exhaust heat may well melt it.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
95 Nissan Pulsar
Owned
Post by Speedy88 » 18 Sep 2013 06:32 pm
Hi Justin,
Halfords do generic fit brackets, they're about £1.30 each and they've gotten plenty of my cars through MOTs.
Post by macplaxton » 18 Sep 2013 06:49 pm
Dimensions 66mm OD x 40mm ID. Cross section diameter 12mm is one set of measurements I have and another is Dimensions 65mm OD x 41mm ID. Cross section diameter 13mm
Walker 81223
Arvin / Klarius 420164
If you're really stuck...
Justin
Post by Justin » 19 Sep 2013 03:45 pm
Thanks everyone, amazingly super glue has held and joined the ring back together!
Its actually just a medium sized oval shaped rubber ring that sits right at the far back of the car connecting one side of the exhaust to the body...
1988 340 1.4 DL
Post by Speedy88 » 19 Sep 2013 04:33 pm
I'd get that replaced fairly soon, the constant vibration on the rubber whilst under tension and with a weak spot will eventually break it open.This time it might be on the road and you'll have to replace it anyway.
Post by Chris_C » 19 Sep 2013 04:45 pm
Not to mention exhausts are a lot more expensive than rubber rings when they fatigue.
Justin
Post by Justin » 21 Sep 2013 04:15 pm
Blimey. Im still not convinced I can source one as the part name and number that macplaxton kindly supplied (Bosal 255-397 ) comes up with a much thicker rubber ring with two holes inside it when typed into ebay as opposed to a medium sized oval rubber ring?...
1988 340 1.4 DL
Post by macplaxton » 21 Sep 2013 08:55 pm
Show me the link please.
Justin
Post by Justin » 23 Sep 2013 12:20 pm
Speedy88 wrote:Hi Justin,
I had a look at the Halfords ones yesterday and they are apparently 50mm, will this do?...
1988 340 1.4 DL
Post by macplaxton » 24 Sep 2013 05:44 pm
Justin wrote:I had a look at the Halfords ones yesterday and they are apparently 50mm, will this do?...
yes
