Hi all, the volvo just failed today on rear brake hose and indicator stalk. Not too bad really .
It has completly snapped off.
If anyone has the replacement ring or a bodge kit to get me through the mot it would be greatly appreciated.
Indicator bracket for mot
Re: Indicator bracket for mot
Is it the switch you need or the bracket?
Hi ,Its the bracket . The tabs have broken where the screws attach to the indicator unit.
If its the bottom tabs A good bodge is just cut and drill some plate steel 1mm or whatever. about 3x1 cm with a hole each end. It will hold it together.
viewtopic.php?f=13&t=9105&hilit=+indicator+bracket
I still have the repaired spare in the picture.
Thanks for the link , ive managed to bodge it for now. Mot retest tomorrow.
Id still like one though if anyone has one . There is still some movement in it when using the flash beam . But it will do for now.
I have a couple of brackets and also some laser cut repair brackets.
Here are the brackets, http://www.classicswede.co.uk/Indicator ... 44766.aspx
