lanndy 90 shocks
Joe
lanndy 90 shocks
Post by Joe »
Hey, had a quick look through the fourm but coudnt find if you could use landrover shocks in the front aswell as the rear + would you use the landrover front shocks for the front and landrover rear shocks for the rear if that makes sense lol Cheers Joe :)
Roll like its your last time and just let the good times roll
Foook power grow some balls and get commited :)
Re: lanndy 90 shocks
Post by classicswede »
Hi Joe,
The only uprated front shocks are my adjustables. For teh rear you can go for my adjustables or use landi fronts
Joe
Post by Joe »
Cheers am trying to do it cheap so i will probly just cut the springs, just wondering but how much are you adjustables
If you are doing it on the cheap then I would say sit down. The fronts are £170 a pair and rears are £130. BTW that is quite cheap for adjustable inserts.
monka
Post by monka »
what year landy shocks fit the back?
littlered
Post by littlered »
trust me buy from dai,you will not regret it
mrsoundcraft
Post by mrsoundcraft »
The original springs are so soft that shortening them wont really help the handling at all. I found a good combination on a budget are some Custom Classicswede lowering springs and KYB or similar shock inserts. I would expect that all original shocks, like mine are so soft they might as well not be there. Oh, I think poly bushes at the front also make a big difference.
As far a rear shocks go I think the most important thing is that they have a threaded bit at the top and bottom, Ive got some old monroe shocks off a Range Rover. I thought I would be better with something a bit older and worn out as I was warned about the stiffness of new ones. Search ebay for Defender 90 or similar.
mat 91
Post by mat 91 »
bit off a tread hackso sorry in advance
but were is every one getting front shock inserts from because i cant seem to find any
thanks mat
OapEM
Post by OapEM »
LR 90's on the back and 80/90w in the fronts FTW - I'm still yet to refill mine. Boinnnnnnggggg!
Get rich or die tryin'!
mrsoundcraft
Mat, try asking for Quentin Hazel shocks at a motor factors or try this website, http://www.buypartsby.co.uk/. I was lucky to get some KYBs from an owner on here. There are some Monroes on ebay I think, worth a look.
mat 91
Post by mat 91 »
kool thanks for that info might have a shot at just refilling them and if im not happy then ill
do it properly i am looking on ebay as we speak so if some come up at a resonable price ill have them
thanks mr sound craft
tommysb
Post by tommysb »
I've had good results with much less than 80/90 oil. I used 35 grade i think, from memory, with 190lb springs. But you could go up a grade or 2 from that comfortably, I'd imagine.
