Volvo 360 Sunroof Parts
Required:
All internal workings for the Golde sunroof as fitted to 360s.. some 340s maybe? Black sunroof panel wouldnt be bad either, but that might be pushing it.
I know of two sets available, I just can't get em! :P
petefarrell360
Post by petefarrell360 »
Steve, have you actually removed the sunroof to see what the problem is. When I swapped all of my internal sunroof components for one's that I knew worked, the only things that were actually broken were the plastic blocks which I seem to remember form part of the runners, in the slot, which also pegs the roof down to stop the back flapping. It may be possible to buy these? Probably not, so I just replaced mine without looking into the possibility. I can't remember what was wrong with yours? Is it jammed? Or does it have trouble shutting, or is the back flapping and lifting once opening? I know it doesn't sit flush, but then that can be adjusted! Just worth thinking about before sourcing all the bits when you may only need a couple.
Pete, theres nowt in my sunroof apart from two nice blocks of wood :D Me and my Dad took a look at it.. there are a couple of small parts but I really want the whole package, including cables! So therefore, it doesn't shut.. it doesn't open, tilt, slide, or anything. However, it makes nice windnoisy sounds and it sits perfectly flush ;)
5lab
Post by 5lab »
hmmmm
Swapsea-'89 360GLT-swapped!
Post by redline »
another hmmm post !
5lab wrote:hmmmm
Can you help Hugh? :lol:
V6 Man
Post by V6 Man »
Whatever you do don't ask Foggy for sunroof advice seeing as he is the only person I know of who can lose one............
