Removing front strut- Advice needed
kelvingenders
Post by kelvingenders »
I'm replacing my front shocks on my 360 GLT Hatch 1986 B200EA and have undone all ball joints and nuts, I cannot get the strut to detach from where it is supposed to. Where should it disconnect from?
a) the brake guard
or somewhere else
b) am i being silly?
Kelvin sm2 :360:
pyro
Re: Removing front strut- Advice needed
Post by pyro »
a) the whole strut comes out from the wheel arch,
b) probably not, have you undone the 3 bolts under the bonnet around the top mount? just give it a tap bit a tapping stick. somthing like a soft mallet wood or whatever.
Ben
* Disclaimer
Mors Principium Est
kelvingenders
All the bolts at the top are undone. The bottom part is still attached but all ball joints and nut have been removed.
Vermilion
Post by Vermilion »
The strut is connected to the body with the 3 bolts on top, steering ball joint and the other ball joint, and with the brake calliper. You can just pull the part off where the cable is attached to, with a bit wobbling. See image for what I mean
Volvo 340 L 1983
Post by Ride_on »
Have you seperated the lower swivel ball joint? Normally I just unbolt the plate it is on, much easier to slid out then.
You may just need to push the lower suspension arm down with your foot and pull the strut out. It will probably be easier if you disconnect the radius arm at the arm aswell.
kelvingenders
Thanks everyone, specially the picture one
Vermilion
Post by Vermilion »
Ride_on wrote:Have you seperated the lower swivel ball joint? Normally I just unbolt the plate it is on, much easier to slid out then.
I unscrewed the swivel with the two bolts which connects it to the suspension arm. Kinda easy when putting it back too, but if you do this for the first time the nuts are probably a lump of rust :x
Volvo 340 L 1983
kelvingenders
Had to release two bolts holding the caliper in place, then Voila!!!Job done
Have discovered another problems - tops of struts, where holes for bolts to go through has cracked in three places....Aggghhhhh
Post by Ride_on »
Yes this is common on 360s they are a bit weak and the newer version is more corrosion proned. The older ones have a dome for the rubber boot and this seems to be better protected. Although looking at it now I'm thinking the older ones are thicker (3mm at the shock mounting point), but I don't have a newer one out to compare. The problem is usually accelerated by heavy duty shocks.
I was able to get parts before, not sure what can be done now, vaguely remember seeing some threads about it.
300 Strut top cup - pre83 approx.
Vermilion
Post by Vermilion »
I think he means this one
Volvo 340 L 1983
kelvingenders
Boys, I got two struts from the wreckers, all part in place and no bearings broken..fixed..Thanks for the help
kelvingenders
Ride on, thanks, the pictures are where the problems were..
Kelvin Brisbane
