My car will start, but as soon as the starter motor stops....after not turning the key anymore, there is about a 2 second groan, a very dull one. It goes away and doesn't come back until it's time to start again. Can anyone advise what might be causing this"groan"
Kelvin
Car is groaning after start up - Any ideas
kelvingenders
- trabitom99
Re: Car is groaning after start up - Any ideas
Could be the starter motor running on?
kelvingenders
Could be, i've never heard of one running on before though. How can you tell if you starter motor is on its way out?
The solenoid ine was sticking OFF and ON, depending on what kind of mood it was in.kelvingenders wrote:Could be, i've never heard of one running on before though. How can you tell if you starter motor is on its way out?
Mine was a 340 though.
Sticking on for a couple of seconds is nowhere near as bad as sticking off!
When mine stuck on, it was more of a grinding scream than sigh though.
Can be, mine stuck on permanently oncevolvosneverdie wrote:The solenoid ine was sticking OFF and ON, depending on what kind of mood it was in.kelvingenders wrote:Could be, i've never heard of one running on before though. How can you tell if you starter motor is on its way out?
Sticking on for a couple of seconds is nowhere near as bad as sticking off!![]()
Could be alternator bearings, mine made noise on start up which then went away so i left it. It died 5months later or so
kelvingenders
Yep, it's my starter motor running on!!!!
