Turbo 360: More potential shell ruining lol
Re: Project B230 360: Fuelling sorted
Hubba hubba, might be a reason to make a northern meet eventually.
That and VND's sexy arse
Speedy88 wrote:Hubba hubba, might be a reason to make a northern meet eventually.
you want to have a word with yourself.
Re: Project B230 360 - Getting closer
Post by classicswede »
L14MNP wrote:
I think the injectors may also be in the wrong order, as they weren't lbled up when removed! Am I right in thinking that if they are trying to fire in the wrong order then it won't want to start at all?
I am unsure how to find out which order the injector plugs should be in on the loom too. :/ It has two longer wires and two shorter ones. Short ones for numbers 2 and 3 perchance?
Does not matter what order they are plugged in as they fire full group. All injectors fire at the same time.
Speedy88 wrote:That and VND's sexy arse
:lol: :lol: :lol: I nearly spat my tea out
Post by trabitom99 »
:shock: :lol:
Great job Liam, well done for managing such huge job in such a short time! The car looks mean in those videos ...
L14MNP
Post by L14MNP »
Here's a belated update lol
As previously mentioned, it was spraying oil out of the return for the turbo, so I whipped it off and replaced the gasket and O ring with OEM Volvo parts, expecting this to solve the issue.
The gasket isn't correct. Despite Volvo using the 940's chassis number to order it:
See how much of the old one was left lol.
The DIY return
Here's the less than adequate space/view you have to work with if you don't remove the mount. I managed to remove the return, but fitting it again this way was impossible.
Despite the incorrect fitment, I stuck it on anyway. Removal/fitting required the radiator out, alternator off and O/S engine mount.
It seemed to have worked initially, no drips when running. It has now started dripping (Noticed on Saturday night. First offcial run out) although nowhere near the previous extent.
So there's still a few things to address. On Friday evening after a couple of hours on it I thought it was ready to go. So at about 3am my mate and I went to Tesco for oil, it was only on the return trip we noticed the lights dimming, wipers slowing etc. Luckily we made it home (15 miles or so on just the battery FTW). It was like Apollo 13 :lol: Blower off, engine fans off. Reduce the amperage for re-entry etc. /gay. LOL
Lesson learned there, multimeter the battery when the car is running. Had I done this initially I would have realised it wasn't charging. This was down to the wire to the dash light not being connected, which actually plugs into the voltage regulator on the alternator lol. I dodn't/didn't know much about alternators but we sorted that.
As can be seen, I have no FMIC atm. Just a cheeky scrapyard bypass until my eBay core arrives.
I still have a few gauges to connect, exhaust brackets to make, the damn oil return again and the FMIC to sort and the water cooling to the turbo housing to reconnect. Did the flow hose come from the 940 header tank? Also I am still running a GLT injection pump. It doesn't seem to cut until fairly high up the rev range in 5th. So it's more than adequate to get someone going. I CBA to fit my uprated pump ATM as it needs a fancy connector.
Despite the superheated air and limited boost/power. It still pulls very well. I have whooped a couple of modern diesels a new Saab Turbo and was level pegging with some form of BMW X5. (before i slowed so I didn't lose the louvre lol) Mostly just to see where I'm at more than anything. It will be good to see what's to come when I have a FMIC and bleed valve with the engine running around 11 psi. :)
it's nice to have a working car again. Thanks to FJ, Gaz, Mark and Naylor for the recent help. Nearly there! :roll: :lol:
STREETO WITHDRAWL
INTO BURNOUTSsince1982
Re: Project B230 360: Update
Yes!
Awesome.
That is all.
Nimminz
Post by Nimminz »
Nice work mate, bring it up the reatil park one sunday when its finished!
L14MNP
Post by L14MNP »
Nimminz wrote:Nice work mate, bring it up the reatil park one sunday when its finished!
Like I did the other Sunday? lol. I was up there to catch a mate, but it was after 9 so you were in bed. :lol:
Cheers once again for the kind words everyone. I will update this when I locate the pics I have taken the last couple weeks (I think I may have deleted them lol).
In the meantime. have one from VND from the last coast meet. 8)
Enter one very scruffy but relatively quick 360 sharing in the company of more retro win.
Here's my help post on TurboDICKS (they aren''t very helpful unless you're in the clique it would seem). This details my current woes!
I have just ordered a banjo fitting to run the uprated pump, and checked the timing marks - they line up.
Any more ideas? To say these parts have cost me a few quid is an understatement! It's nto all bad though, as 80% are service parts, and the other stuff doesn't last forever anyway.
Compression test when I can get another spare pair of hands!
STREETO WITHDRAWL
Do one on sat if it'll see you up man?
pyro
Re: B230FK 360: Chitty chitty bang bang :/
Post by pyro »
Id have a look at the MAFM and do a compression check as you say...
I believe that you can unplug the MAFM and the engine should still run properly ish.
Ben
* Disclaimer
Mors Principium Est
L14MNP
Post by L14MNP »
Aye Ben it would make it up there. it's in daily use ATM but is less than fun to drive. So I just plod along. Cheers for the offer dude, but I dunno if I will make the meet. If the timing belt arrives I may be fitting that and the fuel pump, then if my problem is sorted, a GTS Chris dawes device and boost gauge - the fun bits. lol
Pyro, the AMM seems to be doing it's thing. when multimetred the voltage rises and falls with the engine revs.
STREETO WITHDRAWL
L14MNP wrote:Aye Ben it would make it up there. it's in daily use ATM but is less than fun to drive. So I just plod along. Cheers for the offer dude, but I dunno if I will make the meet. If the timing belt arrives I may be fitting that and the fuel pump, then if my problem is sorted, a GTS Chris dawes device and boost gauge - the fun bits. lol
Might have a bool down if you fancy some hinderance man?
Post by Ride_on »
You might be better on volvoforums.org, its just a standard 940 LPT Turbo. Hey I thought it was the FT you had put in, you will be well impressed with 11psi then!
Anyway, its not a common problem with these engines so there will not be a flood of responses knowing exactly what the problem is. Just follow your best problem solving instincts..which you seem to be doing..check everything.
From your description it sounds most like a weak spark to me. Are your leads leaking onto the cramped chassis or something? Look at it in complete darkness once you eyes have gotten used to the dark. I would say to remove the disty cap and check it for oil, but can you do that without lifting the engine or vent box? Might be better to go for the relocate now.
The ODB is not EODB or ODB2, best to make up a flashy reader (as standard in the 95 940);
http://www.volvoforums.org.uk/showthread.php?t=103378
Nimminz
Post by Nimminz »
haha aye i'm normally off by 9, i have other people needing to put there cars up the drive after mine so they can get out before me :(
