Speedy88's Thirteen:...
mat_91
Re: Speedy88's The Tardis: MOT results
Post by mat_91 » 18 Oct 2010 05:12 pm
glad you got the right colour in then end i hate waiting while the cars been done horrible feeling haha
Post by Speedy88 » 18 Oct 2010 06:16 pm
Cheers all! Yep took it home and fixed all those problems in about an hour. Silly adjustments. Although one of them keeps on coming back - I'm getting condensation on the inside of one of the lights, bung a bag of silica gel in but it doesn't seem to be working yet. Saying that, the bag was sitting in the shed for the past few years!
Any ideas?
Post by volvosneverdie » 18 Oct 2010 08:29 pm
well done indeed dude!
great work.
magnumpi
Post by magnumpi » 18 Oct 2010 08:52 pm
Speedy88 wrote:Cheers all! Yep took it home and fixed all those problems in about an hour. Silly adjustments. Although one of them keeps on coming back - I'm getting condensation on the inside of one of the lights, bung a bag of silica gel in but it doesn't seem to be working yet. Saying that, the bag was sitting in the shed for the past few years!
Any ideas?
Nice work on getting it all welded up, i know mine needs doing but i'm forever putting it off, knowing full well it'll be festering and getting worse :roll:
How has eveyone else popped open the lights to paint the inners?
Do that then reseal them with some silicon or similar?
Post by Chris_C » 18 Oct 2010 09:43 pm
Great news dude.. celebratory beer somepoint soon?
Post by Hell Driver » 18 Oct 2010 10:08 pm
Take the headlamp off, spring open the metal spring clips around the edge that hold the glass on (take care to release the plastic edge of the clip first or you may chip the glass edge). Carefully prize the glass from the plastic case with fingers. The rubber seal should work OK when re-fitted. I've recently taken several sets apart with no problem but not actually put them together again. I'm assuming they will seal back up fine. I once took my MK 1 headlamps apart to clean them and as far as I can remember (although it was over 10 years ago!) they are a similar design and went back together and sealed fine.
I wonder if speedy88's light seals are failing, letting in water? or has the access cap over the bulbs at the back of the light been cross-threaded/left off/not sealing?
343 DL (W 80) :-)
R.I.P. 77 343 DL vario :-(
Post by Speedy88 » 18 Oct 2010 10:47 pm
Very possible, I have a chip in the glass which is at the bottom (because I didn't undo the clips plastic side first!!!) but I can't see why that would cause condensation. Being cheap to the max, I'll find some sealant and see if that works.
Chris_C wrote:Great news dude.. celebratory beer somepoint soon?
Yarp, PM inc.
Post by Speedy88 » 19 Oct 2010 05:54 pm
New low mileage leaf springs! Before this pic the back arch sat just above the top of the tyre. Now...
And a little clue as to what is happening to the old ones:
:mrgreen:
Nimminz
Post by Nimminz » 19 Oct 2010 10:33 pm
Nice one on the MOT pass and i love those stickers
Post by Speedy88 » 19 Oct 2010 11:11 pm
Aww fudge it, some bearings are screaming at me at the front of the engine. The last time this happened luckily I was at Adam's and he quickly made me shut the engine off. 5 minutes later the timing belt tensioner was out and it seized solid within 10 minutes. I'm hoping that it's the same tensioner again because I can replace that without taking the belt off. If it's the other one it's a much longer and complicated story. I hate messing with timing belts :x
mat_91
Post by mat_91 » 20 Oct 2010 10:07 pm
ive took my blue volvos lights apart to paint them and they went back together fine with no condensation the rubber seal does a good job
Re: Speedy88's The Tardis: Tax rebate translates into...
Post by Speedy88 » 09 Nov 2010 03:22 pm
I treated myself.
Also I've been doing a bit of this:
Post by volvosneverdie » 09 Nov 2010 03:41 pm
Dude they look ubber awesome. Wernt from up my way were they? There was some fresh returned ones on eBay recently that I lusted after.
Post by Speedy88 » 09 Nov 2010 03:42 pm
Nope, right on my doorstep these ones.
Post by volvosneverdie » 09 Nov 2010 03:51 pm
Speedy88 wrote:Nope, right on my doorstep these ones.
You did good on them man. Suit the car really well.
