Front spring problem...
bobdylan
Post by bobdylan »
I've received a pair of Classic Swedes Front lowering springs (3inch lower "drift" springs to be exact).
Upon fitting them, it seems the springs are too short for the shock. I say this because when the top bolt is at its tightest, the spring is still loose inside the springs retaining cups.
Sorry I dont know any technical terms haha.
Please can someone help?
bobdylan
Re: Front spring problem...
Post by bobdylan »
mrborrie
Post by mrborrie »
Ask Dai?
764 Turbo 86'|Volvo 144 72|Volvo 360 86'||Volvo 360 GLS 85'|242 77"|
Website: http://www.brick-autosport.com
Facebook: http://www.facebook.com/pages/Brick-Aut ... 98?sk=wall"
Post by volvodspec »
it's normal and i have the very same.
once the weight of the car is on it there aren't any problems. if you use proper shocks to match the springs stiffness even the MOT guy won't notice it
double check if the spring is in it's seats before you mount it though.
Post by Ride_on »
I guess it depends how loose they are, sounds a bit dangerous to me, the weight is not always on the wheels, like when you hit the brow of a hill quickly.
'Yump' as the rally drivers say.
Jonofdoom
Post by Jonofdoom »
i had the same, with the 2" springs... phoned dai to be sure... as suspected, it was a case of drilling holes in the spring cups and jubilee clips holding them down. i needed 2 on the top and just one on the bottom to hold them in place. no weight is on the jubilee clips, they just jocate the springs. sprimgs coming unseated is an mot fail.
Koni Red on regular/hard setting and polybushes on the front suspension seem to do the trick then, with those my springs don't come unseated if i lift the car off the ground at the subframe :D
mrsoundcraft
Post by mrsoundcraft »
I had this too, but its inevitible when you use 3" lowering springs. You're car will drive fine. Dai's solution to this problem was shortened Spax adjustable shocks. cable ties are also good for securing the spring to the top spring cup.
Post by classicswede »
The uprated dampers are shortend for use with the springs. If on original front dampers then you need to clamp the springs in place. I left mine unclamped for ages but the MOT man told me off so I clamped them in. Once I sorted the dampers out I took the clamps off. The clamps are just there to stop teh spring dropping out.
j-ski
Post by j-ski »
ive got the same problem, so i welded the springs top and bottom. but im not able to find harder shocks so the front acts like a bitch on the rebound.
I do the shocks and it is also possible to get Konis again now. The trouble with the koni's is you have to take them out to adjust them but mine can be adjusted on the car. :D
