alley cats
bebbinator
Re: alley cats
Post by bebbinator »
Speedy88 wrote:I think your radius arm needs looking at mate :shock:
whys that mate there doesn`t seem to be anything wrong with it, its awsome to drive .
Re: alley cats
Front wheel looks quite far back in thearch to me. Like someones run it into a kerb or something.
But what do I know! :oops: :lol:
Re: alley cats
Post by filthyjohn »
Is it not just because the wheel is turned to the right?! Looks fine to me.
Re: alley cats
filthyjohn wrote:Is it not just because the wheel is turned to the right?! Looks fine to me.
There you go then.
What do I know. :roll:
Re: alley cats
I'm obviously clueless too then :lol:
What do you mean you already knew that?
Re: alley cats
Your words not mine :P
Re: alley cats
Tbf I agree with speedy, the wheel looks way back. Worth a photo on straight lock if nothing else.
Re: alley cats
Post by volvodspec »
if the ET is low on those rims that will give the same effect as bend arms (more common the arm mounting plates), i agree, straighten the steering wheel and see if the wheel is perfectly centered in the wheel arch
magnumpi
Re: alley cats
Post by magnumpi »
Chris_C wrote:Tbf I agree with speedy, the wheel looks way back. Worth a photo on straight lock if nothing else.
I've stayed out of this so far, as mine looks like the blue one in the previous photo, but only when on lock, the wheel is central to the arch other than that.
Re: alley cats
It's just something I had, the wheels weren't central in the arch at straight ahead and the bushes did a great job. It's worthy of a check if nothing else ;)
bebbinator
Re: alley cats
im pretty sure the wheels are center in the arches but i will take a pic tomorow morning before work to cheak and post up anyway also the wheels are 6/13 with 175/70/13 tyres
Re: alley cats
I'm gonna eat my words here - noticed with the cups today that it does exactly the same as this! :lol: I think with standard or "flat" faced wheels that they dont swing out so much. But deeper dished faces will swing further out. If that makes sense? Its a theory anyway.
Re: alley cats
The lower the ET, the more they'll appear like that. Remember the wheel is pivoting around the steering knuckle, so the outside edge of the wheel will trace an arc around that point. I'm pretty sure that's an optical illusion, you can see the tread on the front. Then again, I'm also sure that nearly all 300s would benefit from new tie bar bushes. :lol:
Re: alley cats
This! :)
