I have a renix number 412 lying around now, just wondered if it was of any use to anyone out there
After £25 + postage
Also have a set of subaru spec wheel studs at 63mm long, perfect for you guys running spacers or want quicker and easier wheel changes
£20 + postage
Located in manchester
Antoni
renix 412 + Longh wheel studs
Re: renix 412 + Longh wheel studs
hey I don't supose you still have that renix do you and is it for a B14. 4E?
B14.3E = 401 (not in UK)
B14.4E = 402 (from 1985 has change up indicator)
B14.4E = 412 (1987ish on) Retarded by 4 deg. to run on unleaded
i think it should be dude, but depends on year of your 340!
Ben
Ben
* Disclaimer
Mors Principium Est
Mors Principium Est
my
is an F Reg but the engine came out of a B Reg so...
Take the engine code of off the engine plate and get the renix that relates to that. Has anything been changed between them, or was it a straight swap?
Early B14's I think require 98octane (they'll be a thread about whether they do or not on here somewhere) as Pyro says, a later Renix will pull the ignition 4 degrees so you'd be safe for 95.
it was a straight swap and the engine number is : 002173619
