Burning oil - advice needed
HI GUYS. I've noticed recently that I've started burning oil :( But it's not at a rate that will hamper me cost-wise (top up every couple of weeks or so) :)
So I need some advice - to my mind there are 2 options:
1. Full engine rebuild at much cost/time but solving the issue.
2. Leave it and continue to top up now and again whilst annoying several people behind me as I pull away from traffic lights.
Is it a good idea to choose option 2? Is it suddenly going to go BANG or will it be a gradual decline?
Advice appreciated!
Re: Burning oil - advice needed
Post by volvodspec »
try to locate a source where the oil enters the combustion chamber or exhaust port, i'd start with the crankcase breather. disconnect the hose that goes to the manifold / intake and see if anything changes about the smoke
if you let it idle and take the oil filler cap of, does the engine start to run different?
Vermilion
Post by Vermilion »
Why not option 3. New engine in? Faster than rebuilding your own ands solving the issue :)
Volvo 340 L 1983
Because it's pointless to waste and not many Williams engines exist. Cost of rebuild is much less than a new decent engine...
I'll try cap off anjo, am I looking for a change in revs?
jup, something like that. if it starts to run different in any way it will mostlikely be pistonrings or breather related (let's hope for the last, that's the cheapest :lol: )
Thanks, I'll try that tomorrow. Another thing to note is I just drove 90 miles cross country and it hasn't lost any power/fuel economy. I'm hoping it's valve seals as they needed doing anyway (plus I can leave it for a bit, like the lazy cheap bastard I am :lol: )
Vermilion
Post by Vermilion »
Ok didn't know it was a Williams :P
Volvo 340 L 1983
jup, valve stem seals are a possibility to
if it hasn't lost any power/economy then the engine itself will probably be fine, you can do a CR test to be sure
I would have said door number 2.
Ha ha ha, number 2.
germ
Post by germ »
a can of ametech restore? http://www.americantechnology.co.uk
i used two cans a few years ago on a hyundai that was burning 2litres of oil + a week and it stopped it completely. surprised it worked tbh, i would say its worth a go. the hyundai had compression problems due to worn rings.
we used some in the plug holes and turned it over to get excess out then put the rest in the oil. bit of smoke on start up and after about 300miles no more oil burning! couple of years later the engine is still working fine. :)
Volvo 340 Image 1988
Fair enough, I'm never a big believer in aditives but might be worth it in this case as it doesn't appear to be rings.
So a little update, I did a due oil change today anyway and lifted the oil cap while running. No noticable change but it did spurt oil all over me a bit. I'm thinking probably valve seals or something similar.
Removing the breather pipe makes it rev all over the place :lol: I'll test that on a hot day when it appears to burn more.
