prop shaft
b10opc
prop shaft
Post by b10opc »
Okay so my prop went after three 5 days of owning the car im getting a stronger prop made but whats gonna go next.
It was the rubber connecting the spline to the outer tube so im getting one made with no rubber im guessi.g it will be the splines them selves next which isnt going to be nice
Has anyone but i strengthend prop on and had more trouble or anything let me know
Re: prop shaft
I take it it looks like this?
In which case, it's not the props fault. No offence, but it's a 1.4, it's not a high power engine. There is no chance that Volvo would have fitted that part to the higher rated 1700 if a 1400 could break it.
I imagine your engine mounts are knackered.
b10opc
Re: prop shaft
Post by b10opc »
Yup you got it
And in all fairness i havent checked the mounts yet i literally bought rhe car drive it and it bwoke ill check them tomorrow but it dosent feel like theyve gone
pettaw
Re: prop shaft
Post by pettaw »
Definitely check the engine mounts, but if they're OK then it might just be a perished prop. The rubber can get perished.
b10opc
Re: prop shaft
Post by b10opc »
Yes checked mounts there nackerd you can rock the whole lot from the airbox i checked the carb to make sure it wernr that and nope the whole engine is rocking where can i get mounts from now then
Re: prop shaft
Post by Ride_on »
Check gearbox mounts aswell (4 on gearbox and diff))
b10opc
Re: prop shaft
Post by b10opc »
Okay cheers ill give it A good wobble when the new prop goes on
