rear wheel bearings
DaveGuy46
rear wheel bearings
Post by DaveGuy46 »
Hi,
Im replacing the rear wheel bearings on my 1989 340 it has the type with the 2 bearings in the hub.
Can u fit the 1 piece bearing in these hubs and if so is it better ?
Re: rear wheel bearings
Post by Ride_on »
Unlikely they can be changed in the hub, the hub is designed differently, but I thought the 89 should have been a 1 piece dual row bearing. There is a couple of good threads on how to change this, not easy but doable with basic tools. I have spare circlips if you need them.
You could probably change the hub if you don't have the right type.
http://www.volvo300mania.com/forum-uk/v ... t=bearings
Post by Ride_on »
Actually just reread that thread, damn good it was :)
You can't change the hub type it seems, but I am guessing you have the later one anyway.
