Valver Help! 340 F7P idleing at 3k???
Basically as the title, for some reason after it warms up my car has started to idle at 3000 rpm? The brakes also feel as if I have lost servo assistance??!! all of the vacume lines seem okay from the inlet manifold and too the servo. Any Ideas????????
89(F) 340 DL F7P - Sold
Clio 182
Clio 182
Re: Valver Help! 340 F7P idleing at 3k???
make sure all the bolts on the manifolds are tight
What zeb said. Check there's no leaks through the inlet manifold. Also, if you can, get some compressed air through the hard line that takes the vacuum from the mani to the servo, just to check if its blocked.
Otherwise, could be the ICV (Idle control valve) or the MAP sensor. Both aren't too expensive to replace.
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Cheers guys, I'm thinking it might be the Idle control valve because if i key it off and on quickly when its running it resets the idle to ~1200.
Many thanks, Ben
Many thanks, Ben
Clio 182
Clio 182
is ur idle control valve joined on to like a lil mini air filter? if so take it off and put ur finger half way over or some one told me you can tap the icv with a hammer
Yeah, to check for manifold leaks, cover the ICV intake with your hand. The engine should instantly stall. If it doesn't you've got a leak somewhere around the intake.
Rev engine to 7K
Win at life.
Covered up the ICV and it still idles pretty well, Ill take the intake mani off at the weekend and re-fit nice and tight.
Cheers Guys.
Cheers Guys.
Clio 182
Clio 182
