Suspension top mounts
kelvingenders
Post by kelvingenders » 11 Jul 2012 09:07 am
Is there an affordable alternative or another fitting? Seems odd that there are no replica around considering there were nearly 1 million of these vehicle sold. Any other cars at the time run a similar or same fitting?
Re: Suspension top mounts
Post by Chris_C » 11 Jul 2012 09:19 am
I'm sure there is, just no one has found one yet :s
Normally I'd suggest checking renaults and the like, given the link, but considering the bearing (top mount bearing) is shared with Montego/Maestro and Ibiza (84 shape) they have to be worth a look.
kelvingenders
Post by kelvingenders » 11 Jul 2012 11:29 am
Ibiza (84 shape)...early seat????
kelvingenders
Post by kelvingenders » 13 Jul 2012 11:18 am
Got in touch with mg club....no luck.......have been in touch with scandix...and asked for them to make strut mounts and engine mounts...we all need to get onto these guys and persuade them to start making these babies.
Post by trabitom99 » 13 Jul 2012 11:26 am
I believe Robbert (volvomania) and/or the V3C are working on getting these reproduced on an exchange basis - but I'm not sure on the current status.
volvomania
Post by volvomania » 13 Jul 2012 11:45 am
The engine mounts front are no problem (340).
Rear can be produced depending on demand. I have asked in the past if these were wanted but did not get any (!!) replies.
NOS I still have a set or 2.
For the strut mounts I need plenty of old worn ones. I have been asking for these now for a very very long time but have collected less than 20 so far.
So I am busy getting other stuff reproduced for our cars that is wanted. Only 1 problem, the list keeps on growing...
Post by trabitom99 » 13 Jul 2012 01:06 pm
How many worn strut mounts will you need for a re- run Robbert?
kelvingenders
Post by kelvingenders » 14 Jul 2012 04:04 am
Spoke to guy at sun coast Volvo (australia).http://www.suncoastvolvo.com/
They are going to give the contact number of a guy that custom makes Volvo mounts etc. They reckon he's done 740 Volvo one before etc. I'll let you guys know if this ever eventuates..
volvomania
Post by volvomania » 16 Jul 2012 07:59 am
To get things started I need 115 mounts in total as a 15% reject is expected in the metalwork.
I have found some 15 so far.
Post by Hell Driver » 16 Jul 2012 01:06 pm
I've noticed that the 360GLS models (or at least both I have and the tops mounts off the parts car, also a GLS) have a different type of mount with more metal. Am I right in thinking these are less likely to fail? Where they an earlier type? I assume that these would be too rare to replicate and there is little point in making two types when one will do.
343 DL (W 80) :-)
R.I.P. 77 343 DL vario :-(
Post by trabitom99 » 16 Jul 2012 03:49 pm
volvomania wrote:To get things started I need 115 mounts in total as a 15% reject is expected in the metalwork.
Phew, that will take a while to build up :-( I have some used ones, but they're far from "knackered" and still have plenty of life left in them ...
Post by volvodspec » 16 Jul 2012 03:58 pm
Hell Driver wrote:I've noticed that the 360GLS models (or at least both I have and the tops mounts off the parts car, also a GLS) have a different type of mount with more metal. Am I right in thinking these are less likely to fail? Where they an earlier type? I assume that these would be too rare to replicate and there is little point in making two types when one will do.
the new type was introduced with modelyear 86, the old ones do last longer as the new design damps more vibrations but unfortunatly we know that this means they stretch out
Post by Hell Driver » 16 Jul 2012 06:24 pm
That explains it then. I have 2 of the later type which are damaged, those can be added to the 15 so far then! I'll use the older ones I have as spares for the 89 340 in case it ever fails on them, at which time 2 more will become available. So eventually all of the cars will end up with old type ones. If anyone else has any to send to Volvomania or are going over to call in on him let me know and I can bring them to the V3M meet to save postage. Anyone with any laying around that are no good make sure they reach him and we might get 20 before Christmas! I suppose the problem is the lack of even a temporoary replacement until a production can be made of new ones.
Is the rquirement for 100 good ones due to a minimum production run?
343 DL (W 80) :-)
volvomania
Post by volvomania » 17 Jul 2012 07:58 am
It is to make it more affordable.
kelvingenders
Post by kelvingenders » 17 Jul 2012 08:46 am
Got some newish top strut mounts. These were taken from an 86 model....
Theres something new/odd/strange, great
or wrong!!!
I've never seen these part before? are they legit. The big piece is a boge make, and is metal...except centre piece. The middle side piece is rubber and in volvo 268720???? Any one advise
