360 dipstick
360 dipstick
Post by bogbasic »
Hello, the dipstick on my 360 does not have obvious max and min marks, just a flattened bit with a crosshatch pattern pressed into it. I take it that the oil level should be somewhere on this pattern.
Post by foggyjames »
Correct...roughly in the middle I guess!
antiekeradio
Post by antiekeradio »
ofcourse not...
just below maximum is ideal.
fit a oiltemp sensor and you'll know why :wink:
I do have an oil temp sensor, and I'm totally mystified...?
antiekeradio
with oil at low levels, the temperature will rise much further under heavy load.
more oil in the pan means a higher thermal capacity. oil temperature will be more constant, and generally lower.
on modern-day engines, oil level can be critical to prevent eery ticking noises on startup. (hydraulic valve lifters)
Understood. My oil temps have been a little higher than usual since I fitted the twin carbs, and lost some oil from my front cam seal (at around the same time). I hadn't associated the temperature rise with oil loss, but it's a fair point!
