Leaf Spings
Leaf Spings
Hey all,
does anyone know where i can pickup a couple of the leaf springs for the rear?
or is it a case of breakers only?
Arran
Arran
Re: Leaf Spings
If only you were on my side of the world mate. i have 4 sitting doin nothing.
									Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
95 Nissan Pulsar
Owned
						86 & 89 360GLT
00 S80
02 Subaru GT30
95 Nissan Pulsar
Owned
Re: Leaf Spings
breakers or this forum.  Never an aftermarket item.
I also have 2 spare (360 GLE) in N.Ireland
Re: Leaf Spings
I will have a pair available fairly soon. Where in the world are you?
Re: Leaf Spings
Getting closer each time guys,
Taunton, Somerset. is where I can be found
Re: Leaf Spings
If there are non local to you then they can be posted. What are wrong with your ones?
Re: Leaf Spings
Try this highly-recommended blokey in Highbridge....
http://www.ebay.co.uk/itm/VOLVO-340-199 ... 2330c23c54
... 20 miles, I think. I got doors, bumpers, cables, etc, from him - he is a legend. His no is 07770 842965.
Re: Leaf Spings
My suspension seems to have dropped on one side, changed the dampers so no better so im assuming the spring has been deformed from sideways abuse
they do look a lil warped from looking at them but the drivers is definitely a different shape
				Cliché Guevara
Re: Leaf Spings
I have 2 360s and the leaf springs on each are different one looks like this - P  and the other is kind of ? shaped on the end where it meets the rear hanger.
Whats the difference between the two?
Re: Leaf Spings
If the loop is not closed around the bush then it suggest the spring is damaged
				Cliché Guevara
Re: Leaf Spings
They are both closed round the bush,it just seems that there are two different types.I've also noticed this on pics of other peoples cars.I should really take some pictures.
						Re: Leaf Spings
Are you sure you arn't looking at the front and rear of the spring? Sorry for the big pic, you can't see the difference of the ends in a smaller version
				Cliché Guevara
Re: Leaf Spings
Open end at the front (under the rear seat) question mark at the rear (under the boot) from memory (and looking at the impact on the bent spring in my pic and remembering the crash), but check pictures in the green books!
Re: Leaf Spings
you can't fit the springs wrong way around as the centering point for the axle isn't located in the center of the leafspring.
