B230ET/FT bits
thododd
B230ET/FT bits
Post by thododd » 07 Oct 2014 06:52 pm
ive been gathering some engine bits lately and i forgot to stop at enough ... ive got 1 full engine, a extra complete bottom end, a pair of inlet manifolds and a futher set of pistons w/ rods. so surpluss atm are;
9mm B230ET conrods
B230FT low comp pistons
1x complete inlet manifold
oil filter arm
a pair of 940 engine mounts
940 B230FT sump
crank pulleys, cambelt covers etc etc
if anyone is need of rods or pistons (ie after melting/destroying some, being juvenile) and they ask nicely, i could be pursuaded to donate them for a cause.... but ideally id like £75 for the lot.
postage available or collect from Bristol/Stroud
Thanks
Re: B230ET/FT bits
Post by filthyjohn » 19 Oct 2014 09:38 pm
You don't have a B230FT/FK flywheel do you? The 'dogdish' type? Could collect as I'll be in the bristol area in a week or so.
thododd
Re: B230ET/FT bits
Post by thododd » 20 Oct 2014 05:59 pm
i do have 1, but its for my engine build. sorry
bristol is quite far from home, isnt it? what brings you to the west country?
Re: B230ET/FT bits
Post by filthyjohn » 21 Oct 2014 12:17 am
Family birthday party mate, a joint function for my cousin and her daughter, for which I need a hallowe'en themed costume :roll:
Re: B230ET/FT bits
Post by Ride_on » 22 Oct 2014 10:58 pm
You can you use the 360 flywheel if you do something different with the ignition. I even think the right renix would work well.
Re: B230ET/FT bits
Post by filthyjohn » 23 Oct 2014 08:53 pm
^^^ I'm probably going to use a trigger wheel at this rate. I have a nice lightened flywheel I can use.
