Diff is welded, but i needed more power, so i bought a F7P from a Clio
I need to find loom wire and help to do it… and my car is a LHD, so i need to relocate the mastervac on the right:
 good luck sorting out the idle issue
 good luck sorting out the idle issue (you need the 2 or 3 resistors attached to the VSS aswell, it has to go from 12v to 5v.)
You do need to connect the 3 wires, the + has to from 12v to 5v, hence the resistors. There are markings on the VSS which make it easy to install the wires.
