Urgent ! Rear wheel cylinder
volvoman
Post by volvoman »
Hi there,
I'm wondering if there some other rear wheel cylinder fitted on Volvo 340 except those for Ford Escort , Capri
Rear Drum.JPG (35.81 KiB) Viewed 58860 times
Re: Urgent ! Rear brake drums
Post by macplaxton »
I see no drum.
I see a wheel cylinder.
This is a drum:
Now either you shouldn't be working anywhere near a braking system, or something has been lost in translation (should your native tongue not be English). As we've had no introduction, I've no idea whether it is the former, the latter or both. :?
volvoman
Re: Urgent ! Rear wheel cylinder
Post by volvoman »
Yes, sir
Wheel cylinder just get confused about it sorry
Post by trabitom99 »
My usual parts website lists 3267314 as being suited to Capri III and Escort II (as well as 340s) so you're probably right ... Just don't go for a Volvo 360 part, these are different due to the larger drum.
volvoman
Post by volvoman »
All my search attempts to find this wheel cylinder failed it's quite rare even master cylinder and brake booster I had to alter it with Renault one so I'm currently looking for some other part to fit in with some modification
Gut gemacht "trabitom99"
My local parts factor lists TRW BWD101 for 19 mm bore (shows a picture that looks like a 340 one) and BWF132 for a 20.6 mm bore (shows a picture that looks like a 360 one)
A TRW site search gives:
http://www.trwaftermarket.com/en/catalo ... D101/#Tab4
and a quick google shows:
http://www.amazon.co.uk/TRW-BWD101-Whee ... B00DPI7EG2
But check yourself to be sure, plus I've never used the seller so normal buyer beware etc
It should be no trouble sourcing a brake cylinder for a 340. In addition to Chris's TRW number, also try:
ATE 24.3219-0903.3
Ferodo FHW026
Bosch 0 986 475 500
https://www.rexbo.eu
http://www.daparto.de
Post by bogbasic »
Hello, I have a few if you're desperate....
volvoman
Post by volvoman »
Thanks to all of you nice folks for stopping by
I'm probably ended up replacing my brake shield
Thanks again really helpful
Joris
Post by Joris »
Would there be much trouble if one uses 340 cylinders on a 360, or vice versa?
Post by bogbasic »
I don't know but from memory they are different and the rest of the setup (self adjusters, etc) is different... Presumably for a reason known to Volvo/DAF !?!?
V360 brake drums are bigger. I can imagine it's not so great to mix the two ...
Post by Ride_on »
They are not compatible, the slot for the 2 ports are at 90 degrees between the 340 and 360.
And even if you physically made it fit, the rear bore is different on the two cylinders and they travel a different distance with the different mechanisms, so you'd likely have a very strange pedal even if it had enough fluid to move it.
