Which wire
benji1985
Which wire
Post by benji1985 »
Hello everyone, I prep for the car i have brought and alarm and immobiliser. i want to immobilise the ignition coil, so from the wiring diagram from the green books, i have found that it is (i think) either the green or black wire depending if i have electronic ignition or not, The year of the car is 1988 but i cant for the life of me remember if she has electronic ignition (the book say that she should).
I am trying to avoid any wires being cut near the key barrel, ie making it hard for them lol!
Could i have a bit of guidance on which wire i should cut so the alarm can immobilise should it need to?
Thank you
Ben
Re: Which wire
Post by Ride_on »
1988 would have electronic ignition, You should have the integrated coil+computer module in the engine bay (renix unit).
benji1985
Re: Which wire
Post by benji1985 »
Ride_on wrote:1988 would have electronic ignition, You should have the integrated coil+computer module in the engine bay (renix unit).
Ok cool, so i'll look for the black wire to cut so then there should be no spark to the plugs.
Thank you
Ben
